Author Topic: Pinion bearing and chipped gear  (Read 2188 times)
Offline PaulS
« on: August 17, 2013, 12:27:28 AM »
I'm trying to decide which bearings to replace and which to keep (to save a few bucks).
Here's the inner pinion bearing (from the D41 rear axle):
That little dent is leaving a mark on the roller.  I can't feel it with my finger, and the bearing moves very smoothly.  If I was just basing it on feel, I'd keep the bearing.  But I'm, inclined to replace it.  Your thoughts?
And problem #2, there's a chip in the pinion (still on the rear D41):
This worries me.  But the chip is right at the end.  The contact patch appears to be in the middle of the gear--and doesn't extend to the end.  So is the chip critical, or can I reuse this part?  (I'd really rather not shell out 300 bucks for a new one!)
-Paul
Re: Pinion bearing and chipped gear
« Reply #1 on: August 17, 2013, 12:58:20 AM »
I'd clean off the burr and use the bearing. The chip looks like metal may have been in and chipped it in the past.
Offline stony
« Reply #2 on: August 17, 2013, 04:24:36 PM »
I would not worry about either.� Looks like the chipped area was ground down after it happened.
« Last Edit: August 17, 2013, 04:24:55 PM by stonyloam »
Terry
« Reply #3 on: August 17, 2013, 05:49:12 PM »
Agreed, run me both.  In 30 years someone will be asking the same thing.
Offline PaulS
« Reply #4 on: August 17, 2013, 09:53:57 PM »
Okay, I'll keep them both.� But I will grind down the edges of the chip.� (Terry--it doesn't look to me that it's been ground already.  But I have the benefit of a close look at it, and not just the one picture.)
-Paul
« Last Edit: August 17, 2013, 09:55:18 PM by PaulS »
