I am about to rebuild a transmission/transfer case from a late Willys wagon having the 1.25" countershaft in the transfer case. I will install this in place of the original transmission/transfer case in my '51 CJ3A. This newer T-case has no emergency brake on the rear output shaft.
I will need to put the rear output-shaft+emergency brake from the old T-case onto the new one. Is this a direct, bolt-on?
I also need a short transmission input shaft to replace the longer one for the 6cyl. engine: anyone have one?
Many thanks for any advice...... Tom
