Author Topic: Transfer case swap  (Read 1232 times)
Offline Tom
  • Miles of dirt roads, little traffic....
Transfer case swap
« on: July 16, 2013, 08:29:31 AM »
I am about to rebuild a transmission/transfer case from a late Willys wagon having the 1.25" countershaft in the transfer case. I will install this in place of the original transmission/transfer case in my '51 CJ3A. This newer T-case has no emergency brake on the rear output shaft.
I will need to put the rear output-shaft+emergency brake from the old T-case onto the new one. Is this a direct, bolt-on?
I also need a short transmission input shaft to replace the longer one for the 6cyl. engine: anyone have one?
Many thanks for any advice......  Tom
1951 CJ3A, assembled from various parts. now with '94 FI, 4cyl Ranger (Pinto) engine, Summit radiator, electric fan, power steering, hyd clutch, disc brakes front,� Chevy tilt wheel, high-backed tra
Re: Transfer case swap
« Reply #1 on: July 16, 2013, 12:16:39 PM »
The parking brake should bolt on. I have several input shafts if you need one.
Is the tcase from the wagon one with a 4" bore where it mates the tranny?
Offline Tom
« Reply #2 on: July 16, 2013, 07:38:26 PM »
Nate, I sent you 2 PMs. If you didn't get them, let me know.
