Author Topic: Axle seal replacement  (Read 2587 times)
Offline PaulS
« on: July 10, 2013, 12:58:37 PM »
How do you pull the axle seals, and the pinion seal.
The manual shows a special tool for pulling the pinion seal--surely there's another way, though?
I have a hook/lever type seal puller.  Is it just a question of applying enough force now?  Or there something else I have do first?
-Paul
Re: Axle seal replacement
« Reply #1 on: July 10, 2013, 01:51:29 PM »
I used one of those hook/lever seal pullers...It took some force...make sure you are hooked on the seal itself and not hooked on the lip behind the seal
This is how mine looked...I guess I didn't get a picture with the seal removed...
« Last Edit: July 10, 2013, 01:53:16 PM by 1955CJ-5 »
« Reply #2 on: July 10, 2013, 02:02:40 PM »
I used a pry bar and do it carefully.
My buddy did make 4 holes (drill it) in it and used big bolt to removing it just by bolting the bolt gently evently in each hole.
Offline PaulS
« Reply #3 on: July 10, 2013, 04:27:44 PM »
Thanks!  Just needed to know I wasn't missing something...
I picked up this set this morning:
The big one worked great on the axle ends.  A couple hits with a hammer, and the seals popped right out.  I tried using the small one on the pinion, but it was too flexible--the hammer just bounced off it.  Luckily, I was just able to get the tip of the big one in between the pinion shaft threads and the seal, and then a couple hits and that seal popped out, too.
There's no seal in the axle tube ends on the front, is there?
-Paul
« Reply #4 on: July 10, 2013, 06:47:00 PM »
Just a bushing in the axle tubes in front...seal is in the hub...The hub/drum seal keeps the wheel bearing grease from fouling the brake linings...
Those are pretty substantial pullers!  I think I need a set!
