Author Topic: EZ short term wiring of gauges  (Read 14691 times)
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« on: May 02, 2013, 05:09:43 PM »
I'm getting close to a 'running chassis' and looking for an easy way to wire up the oil pressure, and temp gauges. Right now I have no wiring. When I got the engine first running, it was with bare minimum wiring - excluding all gauges.
I now want to be able to run the engine and determine A) which gauges/sending units actually work and B) how the engine is running (oil pressure, temp).
Was the 3a originally 6v or 12v? When I got it, none of the gauges were wired, and the PO was using 12v battery. Do I need at least a regulator in between the gauges and the battery?
thanks
1951 CJ3a
F-134 Hurricane engine
Re: EZ short term wiring of gauges
« Reply #1 on: May 02, 2013, 06:07:28 PM »
Originally 6 volt, and the oil gage was mechanical with an oil line to it, the temp gage was a bourdon tube style sender in the head , also a mechanical type gage, and the ammeter was an ammeter.
Best bet for a rolling chassis is to use original gages in a homemade gage panel bolted somewhere... You can even test out your speedometer if desired.
If you are going to use electrically operated gages just match voltage with your battery.  Are you running a 12 volt alternator setup? or a 6 V generator?
Offline 3aJeeper
« Reply #2 on: May 02, 2013, 06:36:45 PM »
Thanks, but i'm dumber than a stump.
The engine is the F134, not an L head....so that tidbit of info just might be important....
1951 CJ3a
« Reply #3 on: May 02, 2013, 06:55:27 PM »
I'm pretty sure the F head still used mechanical gages. Maybe we need some pics of the gages you are trying to use...
What do you have for a charging system?? What does the tag on the generator say, if you have a generator...
« Reply #4 on: May 02, 2013, 08:00:56 PM »
JB,
What Bill said.  Pictures will help us get you going.  To test your ammeter, you will have to hook up the regulator...unless you are running an alternator.
Offline Matto
« Reply #5 on: May 02, 2013, 08:11:33 PM »
Early F head motors in CJ3Bs used the same gauges as the L134. Later on (about 1958) they went to the single combination gauge. Here's a link to the CJ3b "tech tips" page which has alot of usefull info on F head motors.
http://www.film.queensu.ca/CJ3B/Tech.html
Be carefull with the tube to the temp gauge, it's kinda fragile.
Matt
Offline 3aJeeper
« Reply #6 on: May 02, 2013, 08:34:58 PM »
Thanks guys - I'll work on pics. Right now there is nothing. The body is off and all the gauges are still in the dash. I believe it's an early F head ('54).
Yea, I figured I'd just jerry-rig some kinda mounting for them.
Charging system is a 65amp alternator, but don't have regulator. I was just looking to get the engine running and test the oil pressure and temperature gauges to get some feedback on the engine and cooling system. I'm not looking to wire the whole thing together just yet. Lots t do before I get to that stage.
1951 CJ3a
« Reply #7 on: May 02, 2013, 08:50:03 PM »
I'd just use a set of replacement mechanical gages with 12 volt bulbs in them for lighting if you are going to use lit gages. A 12 Volt voltmeter wired in would be pretty simple too. An ammeter is less useful in my opinion for an alternator equipped jeep. The 3A dash holes are a pretty standard size, and gages should be easy to find. You won't need any regulator to run the gages.
Eventually you will need to  figure out how to wire up your alternator and other accessories. You will need to get a matching regulator if it isn't internally regulated. I'd recommend picking up a basic automotive wiring book somewhere.
Offline Matto
« Reply #8 on: May 02, 2013, 08:57:56 PM »
Here's a picture of How the Temp. sending unit mounts in a 54 F head.
« Reply #9 on: May 02, 2013, 08:58:07 PM »
I wouldn't bother with hooking up the alternator. You can run a 4 cyl a long time on a good charged battery.
Offline 3aJeeper
« Reply #10 on: May 02, 2013, 09:01:46 PM »
Good ideas F Bill.
Here's what I have: I think this is the oil pressure sending unit. Not sure if I can or how to use this piece. I've seen replacement units, but not sure how to connect the sending unit to the gauge.
This is the temp sending unit (I think). I tried to use a replacement unit (for the Fhead) but the temperature sending unit did not fit in the threaded hole. It was too big. Is this the right spot?
Lastly, here are the gauges in the dash. The chunks in the oil gauge I think are what's left of a gasket maybe? The Temp unit is in a box somewhere....
You can see how I couldn't pass up buying this jeep...it's got less than 3500 miles on it!! :D ;D
1951 CJ3a
« Reply #11 on: May 02, 2013, 09:04:25 PM »
Ditch the electric temp and oil pressure stuff. The mechanical is better for these old rigs.
Offline 3aJeeper
« Reply #12 on: May 02, 2013, 09:12:02 PM »
Matto - looks like you and I were posting at the same time. Your pic is spot on to what I have. On my replacement gauge however, the nut is larger than the threaded hole. Maybe they sent me the wrong one?? I was careful to order one for the F Head...
In this pic the red arrow is pointing to a brass part where the old sending unit screws in. Is this suppose to be removed? This is what is blocking the replacement unit. It won't thread into that brass(??) part, but looks to be the same size. I does not come out when I remove the other piece. Is this suppose to come out too?
GG - agreed, I would like to use mechanical gauges if possible.
« Last Edit: May 02, 2013, 09:40:02 PM by JBCarney »
1951 CJ3a
« Reply #13 on: May 02, 2013, 09:46:47 PM »
I thought it looked like you had a brass bushing in there..
Probably will need to drive an ezy out into it to remove it... or a large hex bit or even a larger torx bit if you have one might work. It will be damaged and not reusable.
Offline 3aJeeper
« Reply #14 on: May 02, 2013, 10:02:22 PM »
Agreed. I have a mechanical temp gauge (and thx to F ZBill - a solution), but unable to find mechanical oil pressure. Is there such a thing? Do you have a line on where to get one? Less electrical wiring = better for me. �;)
« Last Edit: May 02, 2013, 10:03:08 PM by JBCarney »
1951 CJ3a
