Author Topic: EZ short term wiring of gauges  (Read 14702 times)
Offline Matto
Re: EZ short term wiring of gauges
« Reply #15 on: May 02, 2013, 10:38:09 PM »
I think F Bills right in that someone put a bushing in the head to adapt an electric sending unit. once you remove that bushing, you will need to install one of these bushings to accept the temp probe.
http://walcks4wd.com/temperature-gauge-bushing-at-h.html
   The mechanical oil pressure gage does not require a sending unit. Here's a link to a replacement gauge at Walcks.http://walcks4wd.com/oil-gauge-late-cj2a-cj3a-cj3b.html
This runs from the gauge thru the firewall.http://walcks4wd.com/oil-gauge-hard-line-mb-gpw-cj2.html
This runs fromte hardline to the block. http://walcks4wd.com/oil-flex-line-gauge.html
Matt
Offline 3aJeeper
  • Luvs me a flatfender Jeep!
« Reply #16 on: May 03, 2013, 07:02:59 AM »
� The mechanical oil pressure gauge does not require a sending unit. Here's a link to a replacement gauge at Walcks.http://walcks4wd.com/oil-gauge-late-cj2a-cj3a-cj3b.html
Matt
Thanks Matto!
Even I can unscrew the existing oil pressure sending unit and replace with the flex hose at the block. That's the kinda fix I like! ;)
I'll take a look at the bushings too. The temp gauge setup I have has a nut that looks to be the same size as the bushing that's in the engine now. I bet if I take that out, what I got will fit right in.
« Last Edit: May 03, 2013, 07:06:01 AM by JBCarney »
1951 CJ3a
F-134 Hurricane engine
Offline BMIC
  • Weekend Mechanic
« Reply #17 on: May 03, 2013, 07:49:46 AM »
JB this is my running chassis using this wire diagram. Easy basic setup that is giving me all the info I need.
Offline 3aJeeper
« Reply #18 on: May 15, 2013, 02:11:36 PM »
I thought it looked like you had a brass bushing in there..
Probably will need to drive an ezy out into it to remove it... or a large hex bit or even a larger torx bit if you have one might work. It will be damaged and not reusable.
Finally got an ez out (and some time) to back this bushing out. However, it's not coming easily. Just wondering just how hard do I torque on it? I know that's subjective, but am I in danger of doing something really bad like cracking the block? Although I bet the brass gives long before the block....
Not intending to use anything more than hand power, but if using the air gun is deemed safe, then I'm all in.
1951 CJ3a
« Reply #19 on: May 15, 2013, 02:53:48 PM »
if you cannot get it to turn, take a grinder to the exposed surface of it and sand it down level with the block in two spots, to weaken it. This will also prove to you that it is a separate part...(wire brushing would do the same thing if there is any question of it being a bushing and not just a smaller hole in the head than normal ) Then take a dull chisel and hit it inward to collapse it on itself . You may need to chase the threads in the head with a tap when you are done, or you might get lucky and just need to use a wire brush on them.
Offline 3aJeeper
« Reply #20 on: May 15, 2013, 03:21:41 PM »
F Bill
Thanks - I'll do that if it won't budge.
Do I need to be cautious about leaving any shavings inside the block? I really don't want to have to take the head off if I can avoid it.� :-/
Maybe plug it with a cloth or something? Maybe flushing it out real good?
« Last Edit: May 15, 2013, 04:30:59 PM by JBCarney »
1951 CJ3a
« Reply #21 on: May 16, 2013, 10:22:29 AM »
An old school trick I have used in the past to keep shaving out of places is to use............Shaving cream.  Make sure you get the foam shaving cream and not the gel stuff.  Fill the hole up with shaving cream, get your bushing out, tap the threads, ream out the hole or whatever you need to do and then wipe out the shaving cream and metal bits it catches.
If the foam stats to collapse before you are done with the work, just wipe it out and spray more foam in.
Just a tip I picked up from an old engine builder a looong time ago.  I really didn't believe it until I tried it, but it works.  He used it a lot when he would replace a gasket on a V-8 and didn't want the gasket material to drop into the intake, block or cylinder (depending on which gasket he was replacing).  :)
Offline 3aJeeper
« Reply #22 on: May 16, 2013, 09:32:33 PM »
Shaving cream.....that's....just....awesome.
Talk about thinking out of the box....
1951 CJ3a
