Author Topic: CJ3A Body kit  (Read 27951 times)
Offline CJPilot
  • Shade Tree Mechanic
CJ3A Body kit
« on: December 28, 2012, 09:33:36 PM »
I got a chance to test fit my new tub the other day.
But WOW �:o � I am surprised at how much work it's going to take to get this looking right. �
I knew when I bought it I'd have to drill the mounting, steering column and other holes, and I knew I'd be messing with the fit up but
there are more things wrong than I had planned on. �I'll get it all to work but it'll take some time. �My goal is a vehicle to use around my property
and I'm sure that will happen. �
I found this link listing the problems some one had over on the 2A page. �It pretty much covers the work needed.
http://www.thecj2apage.com/forums/md-juan-body-faults_topic26386.html
Time for a beer er make that a few..
Steve
Re: CJ3A Body kit
« Reply #1 on: December 28, 2012, 09:51:48 PM »
Build the jeep completely, and I mean completely! That's what I did with mine and it made it look soo much better after paint. That way, you are not afraid to cut/beat/drill/weld on it.
« Last Edit: December 28, 2012, 09:52:04 PM by garage_gnome »
Re: CJ3A Body kit
« Reply #2 on: December 28, 2012, 09:53:14 PM »
Steve, if you can document what you have found it will make a great FAQ post. As you do the installation if you can keep track of approximately how much time and what you had to do to fix the tub, and post it here, it will help a LOT of your fellow 3A  people.
Is the primer on your tub e-coat or some junk primer?
A lot of the missing holes listed over at the link were for things that may not be installed on a restomod or modified jeep. Probably better to do youw own on that sort of thing anyhow.
Did they finally get the gage holes correct? Transmission  shifters lining up?
I will be following this one closely!  :)
Re: CJ3A Body kit
« Reply #3 on: December 28, 2012, 09:54:02 PM »
I just looked at your profile, you're in central MA? I'm in Western MA. If you ever want, you are more than welcome to come check out my '53 or my very original '49!
Re: CJ3A Body kit
« Reply #4 on: December 28, 2012, 09:55:39 PM »
Bill, that black primer is junk! I had flakes coming off my tub the size of dollar bills! They spray that stuff right over the oily sheet metal.
Offline CJPilot
Re: CJ3A Body kit
« Reply #5 on: December 29, 2012, 07:44:09 AM »
Bill - �The primer looks OK on the tub and right fender. The passenger fender is more of a glossy finish and doesn�t seem as good. I have not looked at the tail gate or windshield yet. �I have not tried sanding anything so time will tell if this primer is actually adhering to the substrate. � In a previous job I painted equipment, mostly with DuPont Centari and Imron. �I used to use a self etching primer on bare metal. The spot welds have a fair amount of expulsion and I�ve cut myself while running my hand down the side of the Jeep looking for any waves in the panels. � They are not perfect but for an old Jeep, to run around with, I don�t think I�ll be doing and straightening of the panels.
The gauge holes are good (but they would be EZ to fix if needed). �I will be taking a better look at the transmission cut out today.
The emergency brake support behind the Dash Panel is in the way of the foot starter hole (which is missing) �I had to cut the bracket out in order to put the hole in. I�m going to try using my original bracket. I do agree for a resto upgraded Jeep a lot of these things would not be a problem.
GG � I�d like to take a look at you Jeeps� sometime. �The only thing I have to look at for help right now is 2 very rusted examples and a lot of the details are eaten away by salt. Maybe you could PM me with some contact info.
Steve
Offline CJPilot
Re: CJ3A Body kit
« Reply #6 on: December 29, 2012, 08:01:20 AM »
I need some help with locating my gas tank. My original (it came with the Jeep) gas tank doesn�t fit into the new tub right. �It will not lay flat on the floor. It looks like it is being held up out of position by the filler neck hole. �My original tub is so badly rusted I cannot get a good measurement of the location (height) of the filler neck hole.
The gas tank hold down location does not appear to be in the proper location as well.
Steve
Re: CJ3A Body kit
« Reply #7 on: December 29, 2012, 05:59:26 PM »
Hi Steve,
I measured mine. �Original 1949 3A tub. �Reproduction gas tank from Walcks.
Using a tape measure in your same location, I get 6 1/8" to the lower edge of the flange of the filler neck. �I get 6 3/4" to the top of the flange where it starts to bend. �These measurements don't appear to be too far from yours.
My tank measurement from the wall of the Willys to the center of the bolt head on the hold down is 13 1/16". �The biggest difference I noticed is the distance between the edge of my tank and the wall of the Willys...1 1/8". �It's a little hard to tell, but yours looks like it's a bit over 2". �I can't say that mine is correct, but the repro tank lined up just fine. �
Do you have the anti-squeak material under the tank? �This would raise the tank a little, allow you to move the tank closer to the wall, and center the tank neck in the filler hole opening.
« Last Edit: December 29, 2012, 06:01:07 PM by athawk11 »
Re: CJ3A Body kit
« Reply #8 on: December 29, 2012, 06:08:08 PM »
Yes, I was thinking he needs the anti squeak material too.
Offline CJPilot
Re: CJ3A Body kit
« Reply #9 on: December 29, 2012, 09:20:28 PM »
Thank you Tim and GG for the input. �Now that I think about it I guess the best measurement would be from the inside floor to the bottom of the filler neck opening. �My tub is not what you�d consider the same as an original, it seems like everything is off 3/8� to an inch. �I plan on changing the filler opening with my original. �I tried setting my tank on some �� wood, for spacing, �but the filler neck still (just barley) hit the opening. �I kind of think it should be centered in the opening. How thick is the anti-squeak ? �
Had to get out my spot weld cutter. I have not used it for all most 25 years. �
Once I figure out were my filler opening should go I'll plug weld it in place.
Steve
Re: CJ3A Body kit
« Reply #10 on: December 29, 2012, 09:46:49 PM »
Steve,
The anti sqeak is maybe an 1/8".
I measured mine.  5 3/4" from the floor on the inside the tub to the filler cut out.  This may be a bit off.  I did replace my floor pans.  But again, original tub, a repro tank, anti squeak, and it all aligned just fine.
Could the tank be the problem?  After I replaced my floor pans, there was no more sagging floor.  All the sudden, the original tank filler neck didn't fit right.  I had to cut the neck off and reposition it.  Ultimately, this original tank leaked at the fuel line connection, so I replaced it.
Offline CJPilot
Re: CJ3A Body kit
« Reply #11 on: December 29, 2012, 09:51:46 PM »
The repo emergency brake support is not made anything like the original. �So I cut both my original one and the new and improved repo one out . �By the way, its not a lot of fun.
Repo on the bottom
 I positioned the original bracket in my new tub, drilled the bottom mounting holes and then welded the upper in place. That set up the hole location for the emergency brake cable in the fire wall. �Of course the repo tub hole is not even close, so I drilled a new one. That left me with one extra hole and neither one in the proper location.
A couple of plugs
Welded in, Ground flush, New hole drilled, Then add some juice
This is more like my original tub
Steve
Offline CJPilot
Re: CJ3A Body kit
« Reply #12 on: December 29, 2012, 10:03:43 PM »
Thanks for the measurement. My floor to the bottom of my filler neck opening is 5 �� also. �Tank? �I'll post some dimensions tomorrow.
Steve
Re: CJ3A Body kit
« Reply #13 on: December 30, 2012, 11:14:41 AM »
Steve
Can you post a photo of the front of your fuel tank?
Re: CJ3A Body kit
« Reply #14 on: December 30, 2012, 02:04:20 PM »
Steve,
I saw the photo of your tank over on the 2A page. �The filler tube looks to be positioned substantially lower on your tank than either my original or reproduction tanks.
Your current fabrications are looking terrific. �You appear to know your way around a welder. �I doubt I have to add this caution, but welding an old gas tank can be a very dangerous game. �I did reweld my filler tube on my old tank, but I prepped it for a week prior to building up the courage to weld it. �That was a terrifying 15 minutes. :-[
