Author Topic: Foot starter linkage  (Read 3399 times)
Offline Kenny_Kustom
« on: April 01, 2013, 09:28:19 AM »
Could someone post a pic of how the foot starter rod is supposed to attach to the starter/linkage?
Re: Foot starter linkage
« Reply #1 on: April 01, 2013, 09:56:12 AM »
Nate posted this picture on a thread that i started....
http://cj3apage.com/forum-yabb/YaBB.pl?num=1362803414/15
« Reply #2 on: April 01, 2013, 10:16:04 AM »
Yep, that would be how it goes. Your push rod comes down and out of the body and connects to the drive engagement lever.
« Reply #3 on: April 01, 2013, 10:41:45 AM »
Not what I wanted to hear.  >:(
Mine has a rod through the firewall, down to a linkage that runs on top of the trans, over to another lever that pushes on the starter.
« Reply #4 on: April 01, 2013, 10:55:11 AM »
So... Where is it supposed to come through the firewall ?
Right beside my hole, where that spot has been patched ?
« Reply #5 on: April 01, 2013, 11:11:53 AM »
Someone has tried to adapt the utility vehicle type linkage onto your CJ-3A. On a stock CJ-3A the pushrod pedal attaches directly to the starter.
« Reply #6 on: April 01, 2013, 11:13:32 AM »
Mine is right near the bottom of the parking brake brace that you can see in your picture. Looks like bubba did something to yours. I know there is a later version of this linkage. I'm not sure what it looks like.
« Reply #7 on: April 01, 2013, 11:15:00 AM »
Bob posted the same time I did. He is right. Disregard what I said about the other version.
« Reply #8 on: April 03, 2013, 02:12:30 PM »
Not what I wanted to hear. �>:(
Here is a picture of mine..needs a little work!
How do you post those large pictures??
« Reply #9 on: April 03, 2013, 03:01:10 PM »
Are you using photobucket? It looks like you are using the thumbnail links instead of the regular img links.
