Author Topic: Vacuum wiper installation question  (Read 2428 times)
Offline jeffbo1
« on: October 16, 2012, 06:33:30 PM »
I am installing 2 stock vacuum wiper motors on my windshield frame, and if mounted straight away the drive rods seem to protrude a bit too much on the outside of the windshield frame. Does anyone know how much drive rod is supposed to stick out in front of the glass. I would hate to have my wiper arms touching the hood should i fold the frame flat....many thanks
Offline Carls_jeep
Re: Vacuum wiper installation question
« Reply #1 on: October 16, 2012, 11:21:32 PM »
I'll take a shot at it. If your wiper arms hit the hood then make some spacers to move the wiper motors farther away from the windshield frame. If they are after market wiper motors the shafts may be to long.
Offline jeffbo1
« Reply #2 on: October 16, 2012, 11:33:38 PM »
yeah they are stock units, in nice shape....they have a cross arm support structure attached to each motor such that they mount with this structure and stand off normally displaying just enough rod length to mount the wiper arm. Without the supplemental structure such that the motor body is mounted directly to the windshield frame then the rod length seems a bit long....i'll probably mount them as they came and then no worries...i have a sneaking feeling that they cam from an M38, not a 3A
Offline rocketeer
  • Support Our Troops.
« Reply #3 on: October 17, 2012, 08:06:36 AM »
Be aware that the hood blocks for a CJ3A are significantly taller than for a CJ2A specifically for that reason. They should be 2" to 2.25" high.
Offline jeffbo1
« Reply #4 on: October 17, 2012, 11:55:38 AM »
Ok many thanks!
Offline Jesse
« Reply #5 on: October 26, 2012, 04:24:13 PM »
My wiper motor needed about a 1/2 block between it and the frame to fit right. No idea if it was original however
-Jesse
Offline HillBillE
« Reply #6 on: October 29, 2012, 06:37:17 PM »
Just made a new set of blocks for my 3A (originals were long gone) Made them 2" tall, and the wipers clear the hood when folded.
(driver side is vacuum, pass side is manual)
'46 CJ2A Undergoing Resto
'47 CJ2A Parts for resto
'52 CJ3A ser# 452 GB1 10197  "Ol' Sarge"
'80 CJ7 Summer Criuser
'00 TJ DD, trail rider and wheeler
