Author Topic: Pulling/removing Brakes Drums on CJ3a/CJ2a  (Read 37352 times)
Offline dodjh
Re:  Pulling/removing Brakes Drums on CJ3a/CJ
« Reply #30 on: August 18, 2012, 06:10:04 PM »
Last two shots.
Offline dodjh
« Reply #31 on: August 18, 2012, 06:12:57 PM »
The drum walls are smooth and there is no ridge.  There was no lining left on the shoe surface.  This renforces
my theroy they dissabled the primary brakes and uses secondary( E-Brake) for main brakiing.
Offline dodjh
« Reply #32 on: August 19, 2012, 07:26:22 PM »
For any who are following....I removed P. Side F. today and they had lining left.
I think my Drums are fine but does anyone know how much drum thickness is allowable...I guess
miked and where to buy parts from M/C forward.  I'll have to do front end first then E-Brake and then rear.
Unless there is a WIND FALL coming I will be approaching the repairs this way.
Offline dodjh
« Reply #33 on: August 19, 2012, 07:27:16 PM »
Number 2
Offline dodjh
« Reply #34 on: August 19, 2012, 07:28:06 PM »
Number 3 of 5
Offline dodjh
« Reply #35 on: August 19, 2012, 07:28:39 PM »
Number 4 of 5
Offline dodjh
« Reply #36 on: August 19, 2012, 07:29:13 PM »
Last one of this set.
Re: �Pulling/removing Brakes Drums on CJ3a/CJ
« Reply #37 on: August 19, 2012, 09:00:00 PM »
The Utility service manual states the drums can be cut 0.030" thereby making the maximum diameter 11.060".
I'd give Walcks a call and tell them what you have there, an 11" conversion on a CJ, most likely wagon or truck brakes. Send them these photos. They will know what parts you need..
Offline dodjh
« Reply #38 on: August 19, 2012, 09:43:40 PM »
Bob....thanks for the advice....I will try and contact them tomorrow.
« Reply #39 on: August 19, 2012, 11:38:52 PM »
dodjh, if the drums are not grooved I would just use them with new shoes and what ever parts you need. You can have them measured if you want to but with standard brakes your not likely to put enough force on the drums to break them. If you have power brakes it's a different story.
Offline dodjh
« Reply #40 on: August 19, 2012, 11:47:37 PM »
Carl...there aren't any grooves or ridges on the two front drums.
The wheel cylinders are corroded and will need replacing..too much pitting and corrosion powder in them.
Thank you for your advice.
Offline dodjh
« Reply #41 on: August 24, 2012, 08:09:54 PM »
Update....I phoned Carl Walck and e-mailed him pictures of my front brakes.  He said I have station wagon and pick up brakes on my cj3a.
Offline racer 1
« Reply #42 on: August 25, 2012, 08:40:11 AM »
Hang on tight when you get back on the road with her!  An old racers rule used to be the faster you go the more brakes you need!
Your machine must have been pretty fast!!!!! ;)
 Dan
1950 CJ-3A Diamond in the Rough!
Offline dodjh
« Reply #43 on: August 25, 2012, 01:42:52 PM »
racer1....the gears are pretty low but I will keep your advice in my mind.  I haven't driven past 45 or so and that w/o brakes.
When you let off the clutch the gears bring the speed down pretty quick.  The PO used it at a deer camp which I wont but will
put some highway miles on it.
« Reply #44 on: August 25, 2012, 06:45:53 PM »
Those are Bendix (Type 11) Self-Centering brakes. They could be found, are you ready for this, on a Hudson. These probably came off of a model 4-63 (Station Wagon) or 6-63 (Station Sedan) Willys if they are 10" or off of a 2-WD (Jeep Truck) or 4-WD (Jeep Truck) if 11".
The info and instructions on the following link should help you out. One important point when replacing the shoes on this type of brake is that the long shoes always face forward
http://home.comcast.net/~sarahdyoung/hudsonjetbrakes.html
