Author Topic: Pulling/removing Brakes Drums on CJ3a/CJ2a  (Read 37379 times)
Offline dodjh
Re:  Pulling/removing Brakes Drums on CJ3a/CJ
« Reply #15 on: August 17, 2012, 07:12:57 PM »
Number four 0f eight.
Offline dodjh
« Reply #16 on: August 17, 2012, 07:13:30 PM »
Number 5 of 8.
Offline dodjh
« Reply #17 on: August 17, 2012, 07:14:09 PM »
Number 6 of 8.
Offline dodjh
« Reply #18 on: August 17, 2012, 07:14:45 PM »
Number 7 of 8.
Offline dodjh
« Reply #19 on: August 17, 2012, 07:16:00 PM »
Number 8 of 8....there has to be a better way of doing this...right?
« Reply #20 on: August 17, 2012, 07:55:59 PM »
They look like Utility series brakes. Just use Tim and Larry's instructions above excepting there are no anchor adjustments at the bottom.
Offline dodjh
« Reply #21 on: August 17, 2012, 08:50:15 PM »
So the brakes are used on trailers etc. and not specifically designed for use on Jeep vehicles?
Should I cut the eccentric bolts with a torch if they wont loosen up?
I've been trying to free the stud from the bolt and so far it all turns together.
Re: �Pulling/removing Brakes Drums on CJ3a/CJ
« Reply #22 on: August 17, 2012, 08:57:51 PM »
I think the 11" brakes that Charles has on his Jeep are the type that only have the "Eccentric" adjusters and not the "Anchor Pin" adjusters. On this type the bottom of the brake shoes are free to slide up and down on the lower anchor, eliminating the need for adjustment there. More photos would be necessary to know for sure.
OK, got it. Hard to tell from the photos.
« Reply #23 on: August 17, 2012, 09:07:21 PM »
They look like Jeep brakes. Utility series are Wagons and Pickups
Heat from a torch will probably free them up without cutting.
I've been trying to free the stud from the bolt and so far it all turns together. �
As long as the "stud" is turning the adjustment is happening. As you turn the stud rotate the brake drum. You should notice the brake drag changing.
Offline dodjh
« Reply #24 on: August 17, 2012, 09:32:55 PM »
That will be my weekend project...Thanks Bob.
Offline dodjh
« Reply #25 on: August 18, 2012, 05:54:35 PM »
I removed drivers side front and these are photos of it:
Offline dodjh
« Reply #26 on: August 18, 2012, 05:56:00 PM »
Picture two
Offline dodjh
« Reply #27 on: August 18, 2012, 05:56:49 PM »
Number 3
Offline dodjh
« Reply #28 on: August 18, 2012, 05:57:56 PM »
Four of Five.
Offline dodjh
« Reply #29 on: August 18, 2012, 05:58:52 PM »
Number 5
