Author Topic: Pulling/removing Brakes Drums on CJ3a/CJ2a  (Read 37353 times)
Offline dodjh
Re:  Pulling/removing Brakes Drums on CJ3a/CJ
« Reply #60 on: September 18, 2012, 08:20:59 PM »
Bob...they must have.  Today I picked up two (2) lengths of the,"WORKABLE," steel brake line, 40" lengths. One section for the pumkin
line and the other for the M/C to Tee on front axle tube.
Haven't bent any line in a while!
I should be prettty good by the time I finish the back lines!
Offline dodjh
« Reply #61 on: September 18, 2012, 10:47:07 PM »
On the front brakes, does the long shoe face the front or rear?
Thanks
Offline dodjh
« Reply #62 on: September 18, 2012, 11:11:32 PM »
I looked and found out that on the 11" shoes, the long shoe always faces forward.
If anyone has a comment, please poat it.
Thanks.
Offline dodjh
« Reply #63 on: September 25, 2012, 12:55:08 AM »
Does anyone know of a link to show DBL flaring a brake line?
I bought 3/16" line and my old looks like a 1/4".
Also the Hub seal in one Brake Hub is leaking...the Seal # is CR 21101.  Is it suppose to be flush with the outer edge of the inside of the drum...not sunk down in?
« Reply #64 on: September 26, 2012, 09:38:52 PM »
This video was helpful for me.  I choose this one because he used the same double flare tool I have.
He does a pretty good job of describing the process. It's not difficult to do.  It is critical to file the cut smooth as he describes.
http://www.bing.com/videos/search?q=how+to+double+flare+tubing&view=detail&mid=C77A2FAE7663EC7B7A59C77A2FAE7663EC7B7A59&first=0&qpvt=how+to+double+flare+tubing
Offline dodjh
« Reply #65 on: September 26, 2012, 10:51:42 PM »
Thank you athawk11
Offline dodjh
« Reply #66 on: September 26, 2012, 10:57:36 PM »
athawk11...that is the first one I picked on Youtube and it played 4 1/2 minutes and stopped.  Maybe it will play through this time.
Offline dodjh
« Reply #67 on: October 06, 2012, 12:50:18 AM »
Well...I have all front shoes, W/C, M/C, all new lines and ready to bleed to remove air.
To adjust the M/C how do I know how far out to extend the rod for the piston in the M/C?
Doesn't the brake pedal adjustment dictate how far to adjust the plunger rod?
Thank You
Re: �Pulling/removing Brakes Drums on CJ3a/CJ
« Reply #68 on: October 06, 2012, 11:07:09 AM »
Thank You
Yes.
Offline dodjh
« Reply #69 on: October 07, 2012, 12:43:18 AM »
Thanks Larry!
Charles
