Author Topic: Speedy-Sleeve  (Read 4758 times)
Speedy-Sleeve
« on: August 12, 2012, 10:12:26 PM »
Does anyone know the right size Speedy Sleeve for the output yoke??  Also, would it be the same size for the other side of the drive shaft?  I have a small leak.  The gear oil flings onto the exhaust pipe.  It stinks!
Re: Speedy-Sleeve
« Reply #1 on: August 12, 2012, 11:38:32 PM »
Yes I do and I will look them up tomorrow and post them. Be forewarned they are expensive and I will post what I paid for them and where I got them.
Re: Speedy-Sleeve
« Reply #2 on: August 13, 2012, 12:04:40 PM »
Thanks Carl.  I'll look forward to your post.
I know they are pricey.  I'm not sure if I should sleeve the yoke or replace it.  Kaiser has the Pinion yoke for $44.00.  I don't want to spend that if the thing is junk.
It won't have the dust shield either.  Do you know if the original dust shields are removable?
Have you had good success with the sleeve?
Re: Speedy-Sleeve
« Reply #3 on: August 13, 2012, 12:18:30 PM »
FYI those dust shield are removable.  Interference fit.
Re: Speedy-Sleeve
« Reply #4 on: August 13, 2012, 02:43:34 PM »
I got the speedie sleeves from Applied industrial Tech and two sleeves for the transfer case output yokes were part #99155 @ $33.62 each in 2010.
The front and rear pinion yokes use the same sleeve part #99155 and now they are $35.29 each. I just put two on when I rebuilt the engine.
Some auto parts suppliers have them or can order them  but on line or industrial supply houses are usually cheaper.
Follow the instructions and use a thin coat of sealer on the yoke seal area when installing them.
Re: Speedy-Sleeve
« Reply #5 on: August 13, 2012, 03:16:06 PM »
Googling sleeve part number 99155 got this on ebay...
http://www.ebay.com/itm/NATIONAL-99155-Seal-Pinion-/180811313290?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a1931b08a&vxp=mtr
in the low $23. range, with free shipping.
Bet you could get it for less if you looked harder too.. I saw it as high as $62.....
Re: Speedy-Sleeve
« Reply #6 on: August 14, 2012, 07:33:27 PM »
Thank you to everyone for the replys.
I have found a number of sleeves using the part number supplied by Carl.  As Bill mentions, there is a HUGE price difference from supplier to supplier.  Can this be justified?  Is there a difference between a 'National Redi-sleeve', and an 'SFK Redi-sleeve'?
For a few bucks more, I can get a new yoke.  Are these worth the extra expense?  Or are the new Repros, junk?
To all that read this...What would YOU do?
All thoughts are appreciated.
Re: Speedy-Sleeve
« Reply #7 on: August 14, 2012, 10:36:45 PM »
I have wondered the same thing. I don't know if they are all made by one company or not. I just got them from the place I buy special seals and bearings from. The name Speedi Sleeve is a registered trade mark of SKS but I guess some other companies may make the gut they can't call them Speedi Sleeves without license from SKS. National and SKS are good companies.
Re: Speedy-Sleeve
« Reply #8 on: August 15, 2012, 08:25:09 AM »
1-I would try to find a good used yoke.
2-Buy new repro.
3-Speedy-sleeve.
It's just my though. I never work with speedy sleeve before.
Re: Speedy-Sleeve
« Reply #9 on: August 15, 2012, 01:20:28 PM »
You have to decide if you want your original yokes or a Chinese replacement. The sleeves are easy to use and they have the added feature of pushing the seal lip a little wider to make a tighter seal.  Since I am not fond of after market replacement parts I try to use original parts or NOS parts.
I have used Speedi sleeves for many years and they do a good job if done correctly.
