Author Topic: Tank vent?  (Read 3635 times)
Tank vent?
« on: August 13, 2012, 12:56:59 PM »
Coming from the M38 world, have a question regarding the 3A tank set up.  Was there a vent or vent line off the  fuel tank?  On a M38, they had the fording set up and had a tank vent line run from the tank thru the firewall to the aircleaner along with all the other vents from different assemblies.  Now with my set up, I do not have the fording set up but I'm trying to figure out where I should terminate the vent line.  Right now, it's in limbo just ending in the engine bay.  I'm just curious if the 3A had a system that would give me some ideas.  Or I'm open to suggestions to.
Brett
Re: Tank vent?
« Reply #1 on: August 13, 2012, 02:47:45 PM »
I don't know about the rest of the CJ3A's but my tank is not vented, the fuel cap is vented.
Re: Tank vent?
« Reply #2 on: August 13, 2012, 03:10:49 PM »
What does your tank have for connections?  Is it a 3A tank or a M 38 tank?  I would prefer a separately vented tank with a sealed cap, if I had the choice, but like Carl says, the 3A normally has only the cap vent.
Re: Tank vent?
« Reply #3 on: August 13, 2012, 03:20:34 PM »
Mine is a proper M38 tank with sealed filler cap and then a seperate vent line on the top that tank.
Re: Tank vent?
« Reply #4 on: August 13, 2012, 04:09:25 PM »
I'd go with a M38 style vent line then... or go to avent line in the engine compartment somewhere with a filter on the end of it to keep the bugs out ....I take it your filler neck fits your tub already?
Re: Tank vent?
« Reply #5 on: August 13, 2012, 05:18:38 PM »
Just be aware, an M38 tank will not fit into a CJ3A without cutting a larger opening for the filler neck.
CJ2A/CJ3A
M38
Re: Tank vent?
« Reply #6 on: August 13, 2012, 05:31:15 PM »
Brett,  I've got the same set up as you do.  An M38 with m38 tank with a vent in the top.  I don't have a line on it at all.  No need really but I see that it will accept some sort of line.  The cap does not vent.
Re: Tank vent?
« Reply #7 on: August 13, 2012, 06:41:09 PM »
Sorry if my post wasn't clear to all.
I do have an M38 vehicle, with a M38 tank.  The vent does not have a home in it's normal spot at the air cleaner.  It right now goes from the tank thru a line thru the firewall to nowhere.  I'm just trying to figure the best place to terminate it.  I thought maybe you guys might have an idea and thought that maybe the 3A had some sort of set up, I gather it doesn't.
Again sorry if I didn't clarify anything.
Thanks guys,
Brett
Re: Tank vent?
« Reply #8 on: August 13, 2012, 11:33:08 PM »
Well, considering your not going to want to go through water above the floor boards I would think the way it is would work.
Re: Tank vent?
« Reply #9 on: August 14, 2012, 12:30:18 AM »
Like Carl says, just terminate it there in the engine compartment. �And like F Bill says, put something on the end to keep the bugs out. �Maybe a small breather could be purchased or make one from a piece of tubing filled with chore girl or similar mesh material and attach it to the vent line by use of a reducer.
I would rather have a vented tank than a vented cap!
« Last Edit: August 14, 2012, 01:40:10 AM by calvinhunt »
Re: Tank vent?
« Reply #10 on: August 14, 2012, 03:49:26 PM »
Thought back to my R/C airplane days and remebered at one time I used a sintered brass clunk/tank filter. �I think I might give that a go.
Re: Tank vent?
« Reply #11 on: August 15, 2012, 10:44:49 AM »
Good idea.  I've used such a filter before and believe it will work well.  The one I used was a water inlet filter for a furnace humidifier.  It was installed on a 1/4 inch water inlet line.  I'm guessing your vent line is that size.
