Author Topic: Leaf Spring Shackles    Left / Right han  (Read 3162 times)
Offline Shalka04
« on: May 11, 2012, 09:12:39 PM »
If the waether will hold tomorrow i'm putting my axles back on.  I went out and bought new leaf spring shackles, and YES I got two left handed and two right handed.  Do both the right handed thred shackles go on the passanger side and the left handed go on the drivers side.  I've read enough to the point of great confusion so I thought I would ask.  I will post update / status pictures tomorrow as it's raining out.
Thanks in advance,
-John
Offline Bedrock
Re: Leaf Spring Shackles � �Left / Right han
« Reply #1 on: May 11, 2012, 10:10:00 PM »
I think one of the left-hand thread shackle bolts goes on the drivers side front, and one goes on the passenger side, rear. �Both go on the bottom, at the spring eye. �I might have to be corrected on this, but that is how I remember it. �If someone has previosly used a right-hand threaded shackle bolt in the spring eye where a left-hand threaded one should go, it can very difficult to replace it with a left-hand threaded one. �I had to use all right-hand threaded shackles on the front of my jeep for that reason.
Hope this is of some help.
« Last Edit: May 11, 2012, 10:44:30 PM by Bedrock »
« Reply #2 on: May 12, 2012, 12:52:02 AM »
Shalka04,
Bedrock is right. �Here is a quote from page 246 of the SERVICE MANUAL for Universal JEEP Vehicles:
"...six bushings are used with right-hand threads and two with left-hand threads. �The right-hand threaded bushings have plain hexagon heads. �The left-hand bushings have a groove around the heads. �The two left-hand threaded U-shackles are identified by a small forged boss on the lower shank of the shackle. �They are used at the left front spring and the right rear spring with the left-hand threaded end DOWN at the spring eye. �The left-hand threaded parts have been cancelled in the production of Models DJ-3A, CJ-3B, CJ-5 and CJ-6"
« Last Edit: May 13, 2012, 01:32:02 AM by calvinhunt »
Offline Comanche_County
« Reply #3 on: May 12, 2012, 07:25:18 PM »
I will freely admit that the next owner of my 51' is going to have to figure that out by trial and error.  Because I think I completely screwed it up.   ;D
« Reply #4 on: May 15, 2012, 06:55:09 PM »
« Reply #5 on: May 16, 2012, 10:23:44 AM »
PO screwed mine up for me.  All of my shackles are RH thread.
Seems to work.  Not sure why they did LH threads offset in this fashion.
Is there an advantage?
« Reply #6 on: May 16, 2012, 11:33:57 AM »
They're designed that way to prevent them from unscrewing from the action of the springs and shackles while you drive.
