Author Topic: OIL SEAL REMOVAL  (Read 1274 times)
Offline BMIC
  • Weekend Mechanic
OIL SEAL REMOVAL
« on: April 13, 2012, 07:28:29 AM »
The last task after replacing parts, gaskets, cleaning, and painting my Transfer Case was to slide in new shift rod seals. Of course while seating it the rubber seal caught the shift rod cut and I mangled it. Short of taking the TC apart can I carefully drill a series of small holes in the seal to weaken it and then remove it with needle nose pliers or is drilling it too risky?     :exclamation]
Offline Harveynailbanger
Re: OIL SEAL REMOVAL
« Reply #1 on: April 13, 2012, 10:11:52 PM »
I would pull it apart. you are already there, xfer is out and accessible, no reason not too.
Rick,
If the grass is greener on the other side of the fence, try waterin your grass.
46 CJ2A #71804
Offline jamesr
  • If it's not broke, it's not used.
« Reply #2 on: April 21, 2012, 06:12:32 PM »
I agree with harvey wallbanger.  No sense half assing it now.
Home of the 4-wheel drive chicken coup.
