Author Topic: resistor  (Read 1788 times)
Offline CJJay
resistor
« on: April 15, 2012, 12:00:25 AM »
Forgot to ask about the in line resistor. The only way to getit to run was to by pass the one resistor I had from several years ago. It did seem to work on my truck and it won't work on this cj so h do I get a correct resistor to put in line with the coil to not burn out my points.
Re: resistor
« Reply #1 on: April 15, 2012, 09:55:08 AM »
By the sounds of it you maybe converted the jeep to 12 volts from 6?  I did the same thing, but was able to buy a coil from NAPA that has the resistor built in, that way I was able to keep the wiring all according to the manual.
Offline Carls_jeep
Re: resistor
« Reply #2 on: April 15, 2012, 02:46:49 PM »
It sounds like your coil has the resistor built into the coil. Adding another resistor would make the spark very weak.
Re: resistor
« Reply #3 on: April 15, 2012, 06:15:21 PM »
Hey Carl, what I was sayin was to remove all the other stuff, put the wiring back together as defined in the manual, and use a coil with the proper resistor built in.  That way all the voltages are correct at the right locations.
Offline Carls_jeep
Re: resistor
« Reply #4 on: April 15, 2012, 10:56:48 PM »
Yes, we're both saying the same thing.
