My Willys 3A and 3B Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Welcome everyone from the CJ3B!
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
3A, 3B, DJ Technical Knowledge Base
"Original"-- Technical Questions, Answers, Observations
resistor
« previous
next »
Reply
Print
Pages: [
1
Go Down
Author
Topic: resistor (Read 1786 times)
CJJay
Project Jeep (Newbie)
Still Plays With Jeeps
resistor
on:
April 15, 2012, 12:00:25 AM »
Forgot to ask about the in line resistor. The only way to getit to run was to by pass the one resistor I had from several years ago. It did seem to work on my truck and it won't work on this cj so h do I get a correct resistor to put in line with the coil to not burn out my points.
Logged
Gunslinger
Flatfender Master
Cj3a, M38A1,
Re: resistor
Reply #1 on:
April 15, 2012, 09:55:08 AM »
By the sounds of it you maybe converted the jeep to 12 volts from 6? I did the same thing, but was able to buy a coil from NAPA that has the resistor built in, that way I was able to keep the wiring all according to the manual.
Logged
Carls_jeep
Flatfender Master
Re: resistor
Reply #2 on:
April 15, 2012, 02:46:49 PM »
It sounds like your coil has the resistor built into the coil. Adding another resistor would make the spark very weak.
Logged
Gunslinger
Flatfender Master
Cj3a, M38A1,
Re: resistor
Reply #3 on:
April 15, 2012, 06:15:21 PM »
Hey Carl, what I was sayin was to remove all the other stuff, put the wiring back together as defined in the manual, and use a coil with the proper resistor built in. That way all the voltages are correct at the right locations.
Logged
Carls_jeep
Flatfender Master
Re: resistor
Reply #4 on:
April 15, 2012, 10:56:48 PM »
Yes, we're both saying the same thing.
Logged
Reply
Print
Pages: [
1
Go Up
« previous
next »
resistor
