Author Topic: Test photo  (Read 3494 times)
Offline Macgraham
Test photo
« on: January 31, 2012, 01:38:46 PM »
http://s1067.photobucket.com/albums/u424/macgraham/JEEP%20REBUILD/?action=view&current=PC190052.jpg
Just trying to post photos. This is what I found when I took the diff cover off the "beautifully restored jeep".
Re: Test photo
« Reply #1 on: January 31, 2012, 01:45:59 PM »
 :o the ring gear bolts were that loose???? Well, it's a good thing you looked in there. What else have you found half way done? Did you drop the pan and check the main and rod bolts?
Offline Macgraham
Re: Test photo
« Reply #2 on: January 31, 2012, 02:49:21 PM »
The rebuilt engine wasn't rebuilt at all. I had to discard the block, crank and cam. 1and 2 main bearing caps were switched, only  1/2 of a thrust bearing installed and on the wrong side and on and on...... Those bolts on the diff were just like that when I took the cover off. The heads were just getting shiny from rubbing on the housing. This Jeep was a mess!!
Re: Test photo
« Reply #3 on: January 31, 2012, 02:53:11 PM »
Holy cow! That's incredible! Something doesn't look right with the spider gears either. The cupped washer doesn't look right. That's a candidate for a complete overhaul. Makes you wonder what the other differential looks like and, as Carl said, what the engine looks like.
Offline Macgraham
Re: Test photo
« Reply #4 on: January 31, 2012, 03:01:40 PM »
I rebuilt the dana 41. The front end I also rebuilt. It is all in pieces and I am just starting back together. There was also a spun rod bearing in the engine. This has been the Jeep from Hell so far. I bought as a fully restored Jeep. What a surprise.
Re: Test photo
« Reply #5 on: January 31, 2012, 09:08:39 PM »
Mac,
Thats just a cryin shame. Comin from one that had a hell of a time with a rebuild, I got ya man.  Hang in there, the good news is that when its done it'll have your fingerprints on everything, and it 'll be right.
Todd
Offline Matto
Re: Test photo
« Reply #6 on: February 01, 2012, 04:21:13 PM »
Holy Moley! For that kind of money I'd epect to be able to get in and drive from the left coast to the right coast with nothing but an oil change.
Re: Test photo
« Reply #7 on: February 01, 2012, 06:10:57 PM »
I'd be visiting the seller for a pound of flesh and blood.
Offline Macgraham
Re: Test photo
« Reply #8 on: February 01, 2012, 06:21:28 PM »
Am planning to go to Washington St. to have a go at him in small claims court. Lots of guys have been helpful and I have kept real good records. This guy is a bigshot in WA. so maybe he should have some exposure. I sure couldn't lie to someone about something I had for sale. He must be able to disconnect his conscience.
Offline gcroyts
  • Jeep'n
Re: Test photo
« Reply #9 on: March 29, 2012, 01:34:54 AM »
Test response.
