Author Topic: Headlights  (Read 3233 times)
Offline TomJ
  • '51 CJ3A
Headlights
« on: January 12, 2012, 10:26:15 AM »
Hi all:
Getting pretty close to done (will try to get some pictures posted soon), but trying to deal with some final wiring issues.  In wiring up the headlights we get power to both but the right headlight comes on very dimly.  It's not the light itself as we switched them and same deal.  Anyone run into this issue and have any recommendations?  Also ordered the parts to assemble the parking lights, do the bulb fittings simply attach to the cup in the grill or is there a piece that goes into the recess that the bulb holders fit into?
Offline p3ferris
Re: Headlights
« Reply #1 on: January 12, 2012, 11:09:06 AM »
You definately have a bad ground.  run a ground from the battery temporarly to see what I mean.
Re: Headlights
« Reply #2 on: January 12, 2012, 11:59:41 AM »
Yes, bad ground at the headlight plug wiring. The same is true of a dim light anywhere on a vehicle.
« Last Edit: January 12, 2012, 12:00:22 PM by Carlsjeep »
Offline Matto
Re: Headlights
« Reply #3 on: January 12, 2012, 12:18:07 PM »
Do you have one 12 volt bulb in a 6 volt system?
Re: Headlights
« Reply #4 on: January 12, 2012, 01:01:28 PM »
No, he swapped the bulbs with the same effect.
Offline Matto
Re: Headlights
« Reply #5 on: January 12, 2012, 02:55:39 PM »
Your right, I see that now. Thats's what happens when your too poor to pay attention. ;)
Offline Jesse
Re: Headlights
« Reply #6 on: January 12, 2012, 10:43:46 PM »
I was under the impression that the bulb holders were in the back and the bulb was inside the lens or something. I used an older grill with different lights but I think there is a photo here
  http://www.cj-3a.com/installing_an_optima_battery.htm
that shows it in the bottom right corner of the page. You can see the socket sticking out just below the headlight bucket. I thought there was a better photo but I couldn't find it offhand. Maybe this will help?
Offline Jesse
Re: Headlights
« Reply #7 on: January 12, 2012, 10:45:54 PM »
Oh duh I just found the page I wanted
http://www.cj-3a.com/installing_front_turn_signals.htm
This one shows the light socket in better detail.
-Jesse
Offline TomJ
  • '51 CJ3A
Re: Headlights
« Reply #8 on: January 14, 2012, 10:48:06 AM »
Yeah..that was it, tested the ground and that was the problem. Thanks for the tip and the link to the parking light, I've been all through that site but hadn't caught that part.  When the parts came from Willys it seemed like there had to be one part missing but I guess not.
