Author Topic: Allignment  (Read 7216 times)
Allignment
« on: October 19, 2011, 04:25:49 PM »
I'm having trouble finding a description of how to perform an "old school" allignment.  I know I saw it somewhere once upon a time, but am at a loss - can't find it in my service manual.  Maybe I saw it here.  Does anybody have a link to how to do the allignment on a 3A?  Thank you!
Re: Allignment
« Reply #1 on: October 19, 2011, 05:42:12 PM »
I don't have a link, but I may be able to walk you through it and get you close.  The first step is to make sure your components are in good shape, worm drive, drag link, bell crank and tie rod ends need to be in good order or this will probably not help you much.
I raised the front end when I did mine, there is a high spot on the worm drive that is the center of the steering gear; make sure the steering wheel is centered on that high spot as that is the first alignment point. If you crank in the tensioner bolt on the worm drive you can feel the high spot when you turn the wheel.
Now take a solid string, I hooked mine on the rear leaf spring and wrapped it across the rear tire as close to center as you can get, run it all the way to the front.  The string should touch the rear of the rear tire, the front of the rear tire and the rear of the front tire at the same time, you should have 1/8th inch toe in on the front edge of the front tire at that point, if not you need to adjust the toe in by cranking on the adjuster rods on the front.  Go slow as just alittle adjustment makes a big difference.  Hope that helps, I know some other guys will chime in here too, thats cool.
Todd
Offline ventport
Re: Allignment
« Reply #2 on: October 20, 2011, 09:15:36 AM »
I drive a big nail all the way through a piece of 2x6, and use it as a scribe.  I jack up the front of the CJ and put the nail against the front center of the tire and rotate the tire one revolution backwards with the nail making a line in the dust on the tire tread.  Do this to both front tires and then drop the CJ down on the ground and measure the distance between the lines in the front and in the back of the tires.  The difference is the toe in or out. Set it so the measurement in the front is 1/8" less then the measurement in the back of the tires.
Re: Allignment
« Reply #3 on: October 20, 2011, 10:10:18 PM »
Well I seem to have some kind of a weird deal going on here.  Todd, I did as you described (with a carpenter's 8 ft. straight edge - not string) and the right side of the jeep was right on the nuts.  But...the driver side seems out of whack.
When I placed a 4 ft. level across the rear RIGHT side fender (spanning the center line of the wheel), the outer edges of the tire is flush with the outer edge of the fender both fore and aft.  In other words, the edge of the tire, and the vertical sides of the tub are all in the same plane.  I assume this is as it should be.  But...when I put the level across the LEFT side rear tire, the tire is "recessed" in about an inch.  In other words the tub protrudes about an inch out from the plane of the tire.  I have to believe they should be the same on each side.
Using the long straight edge, the left front tire is about an inch out from the plane of the left rear tire.  At first I figured I had a problem with that left front tire being too far OUT on the axle, but now I wonder if the left rear tire isn't too far IN on the axle.
So now to display my ignorance...is there an adjustment that allows you to vary the amount that a wheel is situated "in" or "out" on an axle?  Can I adjust that left rear wheel to come out about an inch?  Can I adjust the left front wheel to go in about an inch on the axle?  By the way, I did perform the measurements from the service manual to verify that I have a square frame, and no problems with that.  Also, the tub seems to be mounted correctly on the frame as best I can tell.  Everything lines up as it should and drives great.
Any ideas would be much appreciated!
Re: Allignment
« Reply #4 on: October 20, 2011, 11:22:10 PM »
Hey Tom,
Before I took mine apart, I had the exact same issue.  Driver side rear tire was inset enough to be noticeable.  I don't know if I still have the same problem.  The tub is not back on yet and I had to do some frame alignment when it was all torn down.  I was hoping the issue would be resolved now that the frame is straight.  I had the axles, brakes broke down to the brake backing plate.  I don't think there is an axle adjustment.  At least not that I could see.
I will be watching your post attentively.
Re: Allignment
« Reply #5 on: October 21, 2011, 12:32:23 AM »
When I came to fitting my new reproduction tub to my overhauled frame I saw that the tub fit best to the frame with the right wheel even with the tub.  That caused the left wheel to be inset a little more than an inch.  I didn't like that.  I saw that there was a little "wiggle" allowance in the fitment.  I chose to take a happy medium and ended up with the right wheel inset about a half inch causing the left wheel to be inset about 3/4 inch.  I'm happy with that.
Fitting and drilling the new tub prior to painting the tub.
Reused the original grille and windshield.
Fitted, drilled, and primed with the old tub in the background.
Offline ventport
Re: Allignment
« Reply #6 on: October 21, 2011, 08:18:31 AM »
Have you checked the offset of the wheels to make sure that they are all the same?  Lay a straight edge across the back side of the rim and measure to the mounting surface where the wheel contacts the brake drum.  All 4 wheels should be the same.
Re: Allignment
« Reply #7 on: October 21, 2011, 10:02:37 AM »
Ideally your measurements should be to the centerline of the frame.. If you have a good flat concrete floor, a piece of chalk, and a plumb bob, you can establish the center line and measure from that out to your tire centerlines......It sounds like something has a little bit of a tweak to it.. At least it isn't as bad as my DJ with the Toyota rear end mounted off center by 4 inches....
Drop a point from each spring mounting bracket on each side, mark it on the floor. Then drop a couple of points from each tire sidewall or centerline. If there is a chance you have different wheels, move one wheel around to each location as you mark.  Use a straightedge and make a line from each tire mark to the others from the same tire.  Connect each spring mount point to the one matching it on the other side of the jeep. Mark the halfway point on each of these. Take a 10 foot straightedge or a chalk line and join all the centerpoints...You should have a line down the center of the chassis   Now take a square and measure the distance the tire marks are from this centerline. They SHOULD  be symmetrical. There is a frame diagram in the manuals with similar measuring done...along with diagonal measurements which can tell if one side of the frame has been knocked back.
Re: Allignment
« Reply #8 on: October 21, 2011, 02:25:35 PM »
Okay, well I've double checked all of the frame measurements as you guys have described and as appears in the Universal Service Manual.  All of my cross measurements agree, but I do have one measurement that is suspect.  This is the B-B measurement which is the distance between the centerline of the rear shackle brackets of the front springs.  It measures 28 1/2 inches whereas the others (A-A, C-C, D-D) measure 27 1/2 inches.  When I compare them to the centerline of the jeep, they are "out" the same amount on each side - 1/2 inch.  So...long story short, the frame appears to be right on in every way with the POSSIBLE exception of this B-B measurement.  Can anyone of you verify that this is or is not the case on your jeep?  I just need to know what you guys are getting for that measurement.  By the way, you can make the measurement on the vehicle - no need to find points on the floor.
Calvin and Tim, glad to hear that I am not alone!  I have to agree with Calvin that maybe the tubs need some persuasion when fitting them.  Tim, what measurements do you get on your frame when you measure across the frame from shackle bracket center to the corresponding one on the other side?
Re: Allignment
« Reply #9 on: October 21, 2011, 06:17:00 PM »
Damn Tom,
I knew you were going to ask me that!  I did the measurements in June this year with the frame totally stripped down and sitting on my garage floor.  I wrote them down as I was measuring, but probably don't have that sheet of paper anymore.
I don't remember the cross measurements being off more than an 1/8" or so.  I wrote that off as the chubbie marks on the concrete with a thick old Sharpie.
My issue was a tweaked frame.  The front driver and rear passenger corners were off the ground and the frame teetered when sitting on the floor.  I also had a good driver side lean.  I got rid of the tweek and fit the tub before painting the frame and the lean was gone.  I was so excited about that, that I forgot to look at my inset issue before I took it apart again.
I could remeasure this weekend to see what I come up with.
I'll keep you posted.
Re: Allignment
« Reply #10 on: October 21, 2011, 06:46:26 PM »
On the stripped frame I just got from Andrew in Rio Rancho, the measurements are 27 3/8   28  27 3/4   27 1/2 and the frame is approximately 29 inches wide, except at the number two position it is about 3/8 inch wider.. It was being prepped for an alternative engine, I dunno if someone bent it a little or if it is as factory.  Also instead of tring to find the centerline I just measured from the outside of one hanger to the inside of the other side.....so it is off by the thickness of each hanger bracket, which is about 3/16 as a WAG.
Re: Allignment
« Reply #11 on: October 25, 2011, 11:25:47 AM »
Hey Tom,
Interesting... my AA, CC measurements are 27 1/2" ... DD= 27 3/8" ... BB= 28".
I have the tub in position.  Fenders, Grille and Hood are not painted yet, but I installed them to align the tub and set the body mount thickness.  I am still aligning, but as it sits now, I will have a 1/2" inset on the rear driver side wheel.
I have another alignment issue, but I don't want to hijack your post.  I'll have to take some photos on that and start a new thread.
Re: Allignment
« Reply #12 on: October 25, 2011, 12:23:41 PM »
Thanks a lot, Tim and Bill for the measurements.  Guess the moral of this story is that after 60 years things move out of spec a bit (or maybe were never exact).  I'm thinking the fit of the tub on the frame is just never going to be exact, so no big deal there.  I do still find that my driver side front wheel seems to be not quite in the same plane as the rear - it is about 1/2 inch further to the outside.  I checked for a bent knuckle arm, checked the wheel offset (thanks ventport),  and other obvious maladies and didn't find anything.  So, about all I could do is to square it up to the front wall in my garage and give it a slight toe in.  At least I know it is rolling straight down the road now and it looks right visually.
One thing I did discover is at first I did alignment with the front end on jack stands.  But when I lowered jeep back down on the ground, I see that things are slightly off.  So...I'm going to re-do it on the ground.  Don't know why the discrepancy but, for this jeep, I think aligning with the weight on the wheels is the best call.  I appreciate everybodies help.  By the way, I did find the alignment instructions in the Universal Service Manual in the steering section - not in the frame alignment section where I was looking.
Re: Allignment
« Reply #13 on: October 27, 2011, 07:45:11 AM »
Tom,
I had the same problem with mine, I adjusted it on the jack stand and when I set it down it was off, had to re do it on the ground. I wonder if the weight of the jeep causes the tires to splay and thus making the alignment different whent he weight is off.  I should have mentioned that before, sorry.
Todd
Re: Allignment
« Reply #14 on: October 27, 2011, 09:03:57 PM »
The outer ends of the tie rods swing through an arc when the suspension is cycled so that causes the toe to change. All alignment adjustments should be made with the normal load in the vehicle while sitting on the ground.
