Author Topic: King Pin Question  (Read 17191 times)
King Pin Question
« on: October 05, 2011, 09:27:52 AM »
CJ3A '49
Pulled the front axle off a few weeks ago preparing for my rebuild. When I removed the upper king pin there was the usual shims. I then removed the lower king pin and guess what shims again! In the repair manual it specs. shims under the top king pin only. I am wondering if the last owner just didn't know what they were doing or do I have a 2A axle? What harm is there in only putting shims under the top and not the bottom. Is there any way to measure the knuckle boss and where would the measurement come off of?
Also the tension on the 2A is lower than the 3A specifications on proper preload according to the manual.
George
Offline Frank
Re: King Pin Question
« Reply #1 on: October 05, 2011, 11:44:28 AM »
CJ3A '49
George
George,
The Shims serve 2 purposes in this application, The pre-load and also to align the knuckle, to center it, Now I made a centering tool for a newer type of axle of this design
It slides into the axle housing, and slotted to expand and tighten in the housing then the install the spindle on backwards and bolt to knuckle housing to find the desired thickness of shim,
Heres the whole speal
http://www.backwoodsgoopinfo.com/goopBB/viewtopic.php?f=2&t=39
Now it is not as critical on these Dana axles because of the location of the axle seal, however still important to center the knuckle, keep things nice and aligned, and the reason you will find shims under the lower cap,
Hope that answers your ?
Thanks Frank
« Reply #2 on: October 05, 2011, 12:37:06 PM »
Thank you Frank - perfect.
« Reply #3 on: October 05, 2011, 07:36:44 PM »
A 1949 CJ-3A front axle should still have the shim packs split evenly between the top and bottom. The change came later but unfortunately I have not been able to determine the exact serial number where it took place. My research leads me to believe the change to top shims only came early in the 1951 model year.
Offline Frank
« Reply #4 on: October 05, 2011, 09:03:13 PM »
Bob,
Are you saying @ some point Old Man Willies dialed in his machining close enough to eliminate the lower shims ?
According to that break down he sure did, no shims on the bottom, although one may add a shim there to align the knuckle housing better, in case its off a bit ?
« Last Edit: October 05, 2011, 09:05:42 PM by Frank »
« Reply #5 on: October 06, 2011, 07:06:01 PM »
Yes, the bottom face of the knuckle was increased by 0.058" to eliminate the need for lower shims.
Offline Frank
« Reply #6 on: October 06, 2011, 09:35:46 PM »
Neat, Thanks Bob,
« Reply #7 on: October 07, 2011, 10:06:01 AM »
That settles it then I'll go with top shims only.
« Reply #8 on: October 07, 2011, 10:33:30 AM »
???? For a 1949 the shims should be evenly split between the top and bottom.
Offline Frank
« Reply #9 on: October 07, 2011, 12:07:47 PM »
Bob, I am a lil confused about "evenly split"...  as I see it to be the shims dial in the knuckle for pre-load and centering, These shims take up errors in machining that evidently Old Man Willies dialed in after a bit, and went with the 50 some thousands extra meat on the bottom knuckle,
Now these shims can be various thickness, So simply evenly splitting them by number ? dont add up, ?? usually the shim thickness can vary from super thin, ,005, to .030
If your concerned about this a alignment tool needs to be fabricated, otherwise its a guessing game,
Regardless, if the thing was happy for years with the shims where they where, leave it the way it was, For sure on the bottom, and dial in the pre load from the top,
Offline ventport
« Reply #10 on: October 12, 2011, 01:15:29 PM »
I think it means split the total thickness between the top and bottom.  So if the total shim pack thickness is .030, put .015 on the top and .015 on the bottom for a total of .030.
Offline Frank
« Reply #11 on: October 12, 2011, 04:57:33 PM »
I think it means split the total thickness between the top and bottom. �So if the total shim pack thickness is .030, put .015 on the top and .015 on the bottom for a total of .030.
The shims on the bottom center the knuckle, align the axle,
Bob mentioned around 1950 the machining was dialed in enough to eliminate the shim @ the bottom , But when aligning  the knuckle to the housing select a bottom shim, and adjust pre load from the top,
Simply splitting the shims evenly defeats the purpose altogether of the bottom shims, they are to center the knuckle housing,
Some sort of alignment tool, is needed, when working from scratch however re using the existing lower shims in a axle that has functioned well for years is just fine,
« Reply #12 on: October 12, 2011, 08:18:10 PM »
That is not what Bob said, this is what Bob said.
Dividing the shims equally between the top and bottom keeps the knuckle centered on the axle for the early knuckles. The change in knuckle machining was done to simplify service by eliminating the lower shims, not because they "dialed it in".
Offline Frank
« Reply #13 on: October 14, 2011, 12:35:34 PM »
Bob, �
"YES"
Bob, I am not mis quoting you , You answered Yes to my question, But now its not that the machining got dialed in, it was ease of service, Maybee So It got to the point that Old Man Willy,s got tiered of guys loosing track of the lower shims, and retooled, ?
Doubt it,
No, Bob I think this is just like the axle end float that is adjusted by shims under the spindle, in the older axles, The machining got better so these shims could be eliminated,
« Last Edit: October 14, 2011, 12:42:17 PM by Frank »
« Reply #14 on: October 14, 2011, 05:34:36 PM »
Frank, your kind of twisting BobW's words. What he is trying to tell you is on '49 and earlier you use shims on the bottom and top and on '50 and newer you only use shims on the top.
