Author Topic: Teardown progress and question about frame finish  (Read 13006 times)
Offline mrman5917
  • 1950 Willys CJ-3A S/N 45360
« on: March 05, 2011, 12:39:17 AM »
Hey everyone, it's been a while since I have posted, but I do check in quite frequently to see what everyone is up to.
Two weekends ago I reached a major milestone in my teardown and removed the body from the frame. I plan on doing a little degreasing tomorrow morning before continuing on the tear down. While helping to remove the body, a buddy of mine and my brother were asking how I was going to "finish" the frame. My brother thought powder coating was a good way to go, while my buddy thought "strong paint" would be a better idea.
So that got me looking and researching. It seems that there is no "perfect" solution. Powder coating seems to have downsides with regards to inspecting for frame cracks and the potential for water to seep under the finish causing rust.
Then there is the POR-15 suggestion, which has some very good reviews, but they always seem to come with a qualification that it can be very difficult to get a "perfect" application that will not peel or cause other issues later on.
So, what has everyone else done to finish their frames? While I'm at it, I might as well ask the same question about painting/finishing the axles. Thanks for any replies.
Kurtis
Re: Teardown progress and question about frame fin
« Reply #1 on: March 05, 2011, 08:19:34 AM »
If your planning to strip, sand blast and paint the frame any quality paint will work. If you just pressure wash the frame and paint it there is a paint that will combine with the rust and metal to form a rust resistant finish. You can leave it that way or put a cover coat on it.
I am planning to paint my small utility trailer with some of that rust conditioning paint this spring. Go to an automotive paint shop and inquire about what they recommend.
« Reply #2 on: March 05, 2011, 09:31:05 AM »
For sunny California you can go with Rustoleum rusty metal primer over a cleaned up surface and topcoat it with black rustoleum.It will be every bit as good as the original finish.
 POR 15 is spendy, should be topcoated, and is a pain to get off your hands, but I have heard great things about it from many restorers. It had many devotees, including pro shops, so it must be pretty good stuff. It is the best thing I have heard of for places you cannot get to to remove rust.
  For Upstate NY rust belt conditions I used to sandblast, use zinc chromate primer, then hardened centari enamel. I would then rustproof with some of the runny waxy rustproofing, making sure to get all the nooks and crannies.
By the way your compresssor will run cooler if you take it out of the box.  ;D ;D
Jeep looks like a fantastic  start...very nice!
« Reply #3 on: March 05, 2011, 11:05:27 AM »
And turn it right side up  ;D
Offline jamesr
« Reply #4 on: March 05, 2011, 11:06:56 AM »
I sandblasted the frame and painted it with rustolium rattle can, then brushed on a heavy industrial enamal.  fSouthern AZ we don't rust!  Painted the differentials, with same enamal.  Used a light tan on the transfer case, trans, and engine, so I could spot oil leaks.  I feared the black would hide any that showed.  Apply the covering that resists the elements in your area.  Keep in mind that the old timers sprayed kerosene or thinned oil all over the underside, and drove on a dusty road to "seal" it.  Mine was coated like that, and it had no rust on the frame, and a little rust on the tub bottom.  The Jeep came from W. Oregon, and I drove it deer and elk hunting in the rain, and snow and mud for 6 years fthere, before moving to S. AZ.  I assume it had been in the NW its whole life when I bought it.  I found a service "sticker" stuck under the hood when I pressure washed it.  It had a 1953 date.  The kind that used to be stuck to the door, under the latch that was used back then.  Jim
Offline mrman5917
« Reply #5 on: March 05, 2011, 07:54:33 PM »
Thanks guys. My plan at this point is going to be to blast the frame. With the poor condition of the frame repair that is blatantly obvious on the front mount for the rear passenger spring, I think the safest bet is to make sure there are no other repairs that are necessary, which will necessitate the blasting of the frame. Now if only I could find a sandblasting shop that is still in business :)
I'm thinking that at this point, I'll get it blasted, repaired where necessary, and then go the Rustolium primer/industrial enamel route.  I really want it to look as close to an "original" finish as possible, but with the strength and longevity that hopefully I won't have to do much upkeep on it once it's done.
I'm thinking about possibly taking my axels to an axel shop down the road to get them checked out and rebuilt, so maybe I'll see what they can do for me as far as a finish. If they don't do stuff like that, or if I don't have them look over it, then I'll just go the same route as the frame. Luckily, the Jeep should remain in sunny So Cal for a long time to come, so I'm not too worried about further rust once I get done with the restoration.
Oh, and Carl, I'll have to give it a try out of the box, I was wondering why the wheels were on top and the hose came out the bottom  ;D
Kurtis
Offline Doug
« Reply #6 on: March 07, 2011, 07:56:04 AM »
Nice looking rolling chassis.   You are getting to the fun part.  Every time I see a CJ3A stripped down to the chassis, I start salivating and looking for my wrenches.    Good luck.
« Reply #7 on: March 07, 2011, 08:52:59 AM »
Check with some hot rod clubs, they may know who's doing sand blasting.
« Reply #8 on: March 07, 2011, 09:22:46 AM »
We have a gravestone and monument place that sandblasts here in town, You might check your local monument folks to see if they  do automotive blasting. (SHeet metal is way different than blasting out stone lettering with a mask, if they offer to do it but hav never done it before watch out.)
« Reply #9 on: March 07, 2011, 09:56:56 AM »
Nice chassis!  I was having the same debate with myself about how to finish my frame.  After much thought, I decided to break down and by some POR-15 and use that.
First off, this is nasty stuff!  Wear gloves, long sleeves etc and don't get it on your skin.  If you do, you will look at for over a week.  Same goes for your shop floor.  I dripped some on the floor over 2 years ago and it is still there.
Now the good parts.....  This stuff covers really, really well!  I had ordered two quarts to do my frame and ended up painting my frame, hitch, front and rear axle housings and the backs off all five wheels along with a LOT of little parts.....with one quart.  It spreads very easily and levels very well, meaning it doesn't leave any brush strokes.  While it is not as "smooth" as a sprayed on finish, it is very close.  Since you supposedly do not have to topcoat it unless it is exposed to sunlight, I only topcoated the front frame rails and the hitch with enamel paint.  I sandblasted everything prior to painting.
The coating seems to be very durable also.  Even though you try to be careful, you still bump and nick things putting things back together.  So far, I have not seen any scratches or cracks in the finish.....even after a buddy dropped my hitch 2-3 ft on the concrete by accident :o  Also, it seems to very pretty resistant to gas and oil.
It is worth it?  Depends.  My project isn't on the road yet so I don't know what the long term verdict is.  Overall, I'm very safisfied with it so far.  As I finish my project up and get it on the road, I'll have a better idea.
Here is a link for photos of the project:
https://www.facebook.com/album.php?aid=98281&id=659115588&l=93beae7176
Offline mrman5917
« Reply #10 on: March 07, 2011, 10:12:10 AM »
Thanks Doug, this really is a fun part of this rebuild. It took me a while to get to this point, because while I was working on the body removal, it just took so long to do. Rusty bolts sure don't like to give up very easily, and it seems they won just as many as I did. Now that it's to this point, all I want to do is keep working on tearing it down :)
That's a great idea Carl, my neighbor down the street happens to belong to a hotrod club, I'll have to ask if they know of anyone around here next time I see him out.
I'll have to see if there are any local Jeep clubs as well and see what they all do and use for blasting and for frame finishing. It seems I change my mind every few days on if I'll go POR-15 or just do a "normal" enamel finish.
Mark, those are some great shots of your restoration. I'm also very jealous of the space you have in your shop for all that. Did you end up getting your body from WillyOverlan (RepliTub) or is it just a "standard" MD Juan replacement? How do you like it now that you've got this far on it?
Kurtis
Offline Matto
« Reply #11 on: March 07, 2011, 08:09:42 PM »
This link is for a product called "Master Series".  I've read alot of good things about it and plan to use it on my frame. The distributor is local to me so I can save some shipping. Good luck with the finish.
http://www.masterseriesct.com/home.html
Offline mud pie
  • Once a Marine....
« Reply #12 on: March 08, 2011, 06:22:22 PM »
Nice looking rolling chassis. � You are getting to the fun part. �Every time I see a CJ3A stripped down to the chassis, I start salivating and looking for my wrenches. � �Good luck.
I agree there !!
Each time I see one, I go, "I wanna do that !!"  Then I get into the tight confines of my garage and reality steps in.  I just ain't got the room; too many toys in there....
But I still WANT to...... :-/
1953 CJ-3A
Offline Doug
« Reply #13 on: March 08, 2011, 06:54:57 PM »
I have found the best thing for those rusty bolts is a 11,000 rpm angle grinder and a drill bit. � �If I had the money it would be a plasma cutter instead!!!! Sometimes it's just not worth trying to unscrew a rusted nut and bolt. �Now if it is in a critical place like engine or tranny block, then you have to be careful and get it out. �But on the frame, I use the big hammer principal of mechanics to strip it down. �Keep us posted with pictures. �Have lots of fun!!!!!
« Last Edit: March 08, 2011, 06:55:23 PM by DougP »
Offline mrman5917
« Reply #14 on: March 08, 2011, 09:41:29 PM »
Mud Pie, I have a three car garage with 1/3 dedicated to just the Jeep and I still don't have enough room.
Doug, I eventually resorted to that. More than anything else I was trying to take my time and do as much inspection as possible. I really wanted to make sure that once I had my assistants at the house to pull the body off, I didn't want to have some bolt hanging on or, worse yet, cause damage to the frame or body during bolt removal. I really took my time with the bolts that went into the frame, but once I got to just the outrigger mounts, most of those were far to gone to remove "cleanly" with non-destructive tools.
Thanks again guys for the replies, it seems like every time I post here I get even more excited about the restoration. The goal this weekend is to pull it back out to the street and do some more de-greasing and then continue on the teardown. I'm hoping that in the next few weeks I'll be removing the axels and suspension and getting the frame off to the blaster. My "Willys Fund" has finally grown to the point where I should be able to at least get through the frame and suspension work before having to slow down while funds build up again.
Kurtis
