Author Topic: Teardown progress and question about frame finish  (Read 13023 times)
Offline mud pie
  • Once a Marine....
Re: Teardown progress and question about frame fin
« Reply #15 on: March 09, 2011, 12:09:33 AM »
That's one of my problems...I can't roll anything out into the street for cleaning the grease off it.  I live in a neighborhood that has HOA (Home Owners Association) *'s.  If they saw I was washing old grease and oil off my Willys onto the the hallowed grounds of our subdivision......GASP !! :o
They'd be out there in hazmats suits and clipboards before the cleaner hit the curb....
1953 CJ-3A
Offline jamesr
« Reply #16 on: March 09, 2011, 10:25:20 AM »
Take it to the common area.  Jim
Offline mrman5917
  • 1950 Willys CJ-3A S/N 45360
« Reply #17 on: March 09, 2011, 12:09:43 PM »
That's actually one of the reasons that I park the Jeep under a street sign for our still-under-construction sub division that says there is no HOA when I do that sort of thing. �8-)
« Last Edit: March 09, 2011, 12:10:03 PM by mrman5917 »
Kurtis
« Reply #18 on: March 10, 2011, 04:46:28 PM »
Well, I ended up going with a Repli Tub from WillysOverland. �While it is not perfect and still requires some "slight" changes, it did pretty much bolt right up to the frame. �In this respect, it did save a LOT of time compared to a standard MD Juan tub. �Each situation is different, but here are the major issues I have:
1. �One of the factory fenders did not line up with the repro tub. �However, I had bought the entire body kit so I just used one of the repro fenders and it fit fine. �Since I had to buy a windshield frame and hood, it was just as cheap to buy the entire kit instead of individual pieces.
2. �I'm still working on the e-brake bracket. �Search the 2A website if you are unfamiliar with this problem.
3. �You still have to drill all your holes for your seat mounts, footmans loops, mirrors, spare tire carrier, gas pedal mounts, ect.
4. �The top mounting brackets and gas tank brackets still have to be welded on.
There are a few other little things, but those are the big ones. �And remember, you are dealing with clean, new metal so it is not as bad as it sounds. �However, you do have to take a few shots of "courage" before you drill that first hole.. :o
« Last Edit: March 10, 2011, 04:47:06 PM by macrisel »
Offline mrman5917
« Reply #19 on: March 10, 2011, 10:37:13 PM »
Hmm, I'll certainly have to weight that in my decision making. I've been toying with the idea of using a RepliTub for a while, but then I bought a second parts Jeep. Between the two bodies, I've got one nice clean one with only minor repairs necessary, but not being a welder nor one with much metal work experience at all, I don't think it would be any cheaper repairing the two old bodies versus buying a new one. Hopefully once I can get the bodies sand blasted I'll be able to make a better judgement of the remaining metal and talk to a few body guys and see what they suggest.
Kurtis
Offline Doug
« Reply #20 on: March 11, 2011, 12:53:14 AM »
Either way you go, you are going to need access to a mig welder and someone who knows how to use it. �With the replitub it will be minimal but still needed. � If you have a mig welder and you miss drill a hole, they are easy enough to fill. � �There are lots of poeple around with small mig welders. �And you do not need an artisan, just someone with some basic welding skills. � So either way you go, I would start looking around for someone with some welding equipment and basic skills. �You will need it before you are done. � � I ended up buying my own and teaching myself some welding. � That was probably more expensive route but I wanted the learning experience. � You can rent them pretty cheap too. � �But you have to know a little bit about using a welder. � Fixing the e brake to factory style is not rocket science,  finding the bracket and welding upside down are the hardest part of that task.   If I had known about it in advance of mounting my tub, it may have been easier to weld with the tub on its side or even upside down.  If you are a stocky built guy, you will not enjoy wedging yourself under the dash and trying to weld with the welding tip inches from your face.
« Last Edit: March 11, 2011, 12:56:38 AM by DougP »
Offline mrman5917
« Reply #21 on: March 11, 2011, 10:20:42 AM »
Thanks for the reply Doug. My father-in-law was a professional body guy for many years back east before moving to California, and a friend of mine has two welders in his family that can fabricate just about anything out of metal, so I've at least got a few resources. However, I think at some point I will want to start doing it myself, if nothing else for the experience of being able to weld. Might be something I look into as I go along, I can't imagine that it would be an unused investment having a 60 year old Jeep around :)
Kurtis
« Reply #22 on: March 12, 2011, 09:06:42 AM »
Hey guys,
On that sandblasting, I've restored about 10 old tractors now, we quite sandblasting them because the mess was so bad, and its pretty spendy.  Instead we use a high pressure water blaster with heat.  It does a much better job of getting the old grease off and when your done its pretty hard to tell the difference between the pressure washed and sandblasted areas.  Northern tool has these pressure washers, you need one that has at least 2500psi, and ours has a diesel fuel heater that heats the water to about 200 degrees before it goes to the pump.  Works great.  And no clean up as its just water. For primer we use an industrial grey or red from NAPA and we top coated with Acrylic from NAPA as well, the NAPA single coat acrylics are made by Sherwin Williams, have a 99+ gloss and are extremely durable and easy to work with, especially if you catalyze them.
Kepp em spinning !
gunslinger
Offline mrman5917
« Reply #23 on: March 14, 2011, 11:41:09 PM »
Does it do any good against old paint and, more importantly, rusted metal? I guess I just assume that an abrasive would be necessary for that.
Kurtis
« Reply #24 on: March 20, 2011, 09:33:55 AM »
The power washer with heat will remove all the paint down to the steel as well as any loose rust, you can also add in chemical treatment at the injector nozzle.  Some of them also have the ability to inject small amounts of sand into the water stream.  I've never tried that but I have seen the results.  Just as clean as a white metal blast and no where near the mess.  I just sand blasted a draw bar for my 3B, it was winter so no water this time.  I went through about 100 lbs of sand, my back is still sore!!! :P
