My Willys 3A and 3B Community
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Welcome everyone from the CJ3B!
Willys is a big family.
Home
Help
Search
Downloads
Gallery
Login
Register
3A, 3B, DJ Technical Knowledge Base
"Original"-- Technical Questions, Answers, Observations
Brake slack removal kit
« previous
next »
Reply
Print
Pages: [
1
Go Down
Author
Topic: Brake slack removal kit (Read 2046 times)
macrisel
Flatfender Master
Always in the middle of a project
on:
December 14, 2010, 02:44:58 PM »
So, thanks to the info from Doug I have a link to the brake slack adjusting kit.
Here is a link to a brake slack removal kit install. The bolt tightening was a dealer installed fix to worn brake and clutch pedals. The other method would be to remove the pivot which is welded to the frame and replace it with a new one. On cj3a the pivot was welded to the frame. On the M38 the pivot could be unbolted and replaced without welding.
http://www.cj3a.info/tech/pedalslack.html
My question for everyone is this: what has different people done to resolve this wobble issue in their Jeeps? Since I already have my frame completly finished, I really don't want to grind off the pivot and replace it.
Has anyone put a bushing into the brake and clutch pedals?
Are these slack removal kits still available or does everyone piece a similar fix together on their own?
Logged
Mark
1951 CJ3A �
Photos of build progress:
https://www.facebook.com/media/set/?set=a.62872370588.98281.659115588&type=3&l=93beae7176
Carls_jeep
Flatfender Master
Re: Brake slack removal kit
Reply #1 on:
December 15, 2010, 11:08:27 AM »
My brake pedal wobbled side to side so I cut a slot in a piece of 1/4" thick flat iron and screwed it to the floor to trap the pedal. So far it has worked just fine.
Logged
mud pie
Flatfender Enthusiast
Once a Marine....
Reply #2 on:
December 15, 2010, 09:21:58 PM »
I just ordered all the needed parts to rebuild my brake/clutch setup, as my slop was really bad. I even had to order the tie bar (a part you'd think would never wear out), as mine had a section missing
I'll let you know if all the work actually gives me "normal" pedals.
Logged
1953 CJ-3A
jamesr
Willys Guru
If it's not broke, it's not used.
Reply #3 on:
December 16, 2010, 09:02:50 AM »
I replaced both ball ends, the linkage arm tube, and all the seals, springs, etc. I have no wobble. I also drilled and threaded it for a zerk at both ends to lube it later, and packed it with grease before reassembling itl Jim
Logged
Reply
Print
Pages: [
1
Go Up
« previous
next »
