Author Topic: Radiator  (Read 3897 times)
Offline jamesr
Radiator
« on: October 29, 2010, 10:58:02 AM »
My '53 CJ3A radiator is marked "Golden State Rad" on the brass tag.  Anyone heard of them?  I assumed my Willys was all original.  What do you all know about it?
Jim
Offline Doug
Re: Radiator
« Reply #1 on: October 29, 2010, 04:48:42 PM »
I think all the radiators were made by Harrison like the heaters.  Not sure though.   Bob W would probably know for sure.
Re: Radiator
« Reply #2 on: October 29, 2010, 04:52:38 PM »
Bottom mounted radiators were made by Jamestown Metal. Side mounts were made by Harrison and another manufacturer I have not identified yet. Golden State Radiator sounds like the name of a repair shop. Is that name on a tag that is soldered to the tank?
Offline jamesr
Re: Radiator
« Reply #3 on: October 30, 2010, 10:53:36 AM »
Yes, that brass nameplate is soldered at an angle to the top tank on the drivers and engine  side, just below the top.  It is at a 10 and 4 o'clock angle.  The tag reads (top row) "004019" and below that is "Golden State Rad".  On the passenger side of the top tank is the serial number "649638". The tanks are of brass and the foverflow tube is of copper tubing.  I have Googled "Golden State Radiater", but get nothing (except Golden State Manufacturing".  It is a good, well made radiator.
As a side note, when I was cleaning the underside of the hood, I found an oil change sticker under all the dust/oil, stuck on by a dealer from Waldport, Oregon dated 1953.  I bought the Willys 15 years ago, when I lived in Oregon. I am about to fire the engine up, and drive the "rolling chasis", hence the grill and radiator work brought this up.  My wife asked how I was going to drive it without the tub, and I said "well, if Fred Flintstone did it, so can I".  She had that deer in the headligfht look and said "your crazy".  Yea, I expect most of us are.  Jim
Re: Radiator
« Reply #4 on: October 30, 2010, 06:40:59 PM »
Sounds like a Harrison radiator that was repaired at some point in time by Golden State Radiator Work's, Inc in Hayward, CA.
