Author Topic: Fuel strainer  (Read 3842 times)
Fuel strainer
« on: September 03, 2013, 04:29:25 PM »
I'm thinking about installing an aviation fuel strainer, with a drain, in the steel fuel line inside the engine bay. I would use a compression to 1/8 or 1/4 fine thread connector on each side. USE? To drain ethanol-induced water from the low point in the system. WHADDAYA THINK?
Re: Fuel strainer
« Reply #1 on: September 03, 2013, 04:53:09 PM »
Lowest point.....as in on the frame rail? I wonder if there is room back by the tank.......not much room down by that exhaust pipe and master cylinder....A water separator sound like a good idea with the gas they sell nowadays.
How do airplane guys do it? I know the pilot gets to tap off a little fuel from the tanks before flight, maybe a simple tee in the line and a drain tap might do it too..
Re: Fuel strainer
« Reply #2 on: September 03, 2013, 07:12:03 PM »
The device I install will have a sump with a drain at the bottom. A bracket will attach it to the fender. One option I'm not particularly fond of is the install a "tee" with a simple push-in-to-open valve which is standard for fuel sampling on an airplane wing tank. I'll cut a section for it out of the primary feed pipe and secure the lines with the connectors I described. With the water situation I think I need to start treating the old jeep like an aircraft and do a complete "Pre-drive Inspection" every day with a fuel sample taken. If I detect water, I'll simply drain into a container till nothing but fuel shows up. SOP. I'll fully document the experiment.
Offline zooke581
Re: Fuel strainer
« Reply #3 on: September 26, 2013, 06:24:47 AM »
Interesting.  Keep us posted.  Talk to you more about it next weekend.
Offline stony
Re: Fuel strainer
« Reply #4 on: September 26, 2013, 12:01:33 PM »
How about a marine filter/water separator?  There are a couple with clear bowls, that can be drained.  Might be a better choice for a Jeep.
Terry
