Author Topic: Fluids  (Read 7599 times)
Offline SteveZ
Fluids
« on: February 11, 2014, 08:24:40 AM »
I am going to PM my new to me 2A and want to change all the fluids in the transmission, transfer case and front/rear differentials.
I found this at NAPA - Gear Oil, GL-1 90 Gear Oil; 80w90
I've done a ton of reading and ended up more confused then when I started :o
Am I safe to use this in all of them?
Semper Fi
Re: Fluids
« Reply #1 on: February 11, 2014, 09:29:59 PM »
Yeah, you should be fine. Thats what I use.
Re: Fluids
« Reply #2 on: February 11, 2014, 11:22:44 PM »
Here at the 3A, I believe you will find that the GL1 is the recommended choice for the tranny and transfer cases.� Believe it or not, 30w non detergent oil is also a good choice.
According to the manual, the right choice for the differentials is a 90w hypoid oil.� This would be any of the current GL5 extreme pressure hypoid gear oils available at all auto parts stores.
Offline SteveZ
Re: Fluids
« Reply #3 on: February 16, 2014, 10:30:26 AM »
So, no GL1 Mineral Oil in the Diff's?
Semper Fi
Re: Fluids
« Reply #4 on: February 17, 2014, 04:40:20 PM »
Offline SteveZ
Re: Fluids
« Reply #5 on: February 18, 2014, 07:18:09 AM »
Not trying to get into a "lubrication" debate. But I've got a 5 gallon bucket of the Napa GL1.
So I have a clear understanding--- The GL1 goes into the Transmission & Transfer Cases but I'll need a straight 90W GL5 Hypoid Gear Oil for the Differentials correct?
Thanks again.
Semper Fi
Offline F Bill
Re: Fluids
« Reply #6 on: February 18, 2014, 08:37:38 AM »
Thanks again.
You've got it. The way I understand it and I'm no lubrication engineer, is we need the GL1 to avoid the damage a modern gear lube could do to the brass parts of our transmissions, but in the differentials the hypoid gears need a hypoid lube that will hold up under the extreme pressure between the ring and pinion. No brass in the Diff, so GL-5 is fine.
Sounds like you have a lifetime supply of GL 1.  :)
Offline SteveZ
Re: Fluids
« Reply #7 on: February 18, 2014, 09:50:14 AM »
Thanks again. Sorry to be a PITA!
Semper Fi
