Author Topic: First Time On The Road  (Read 11264 times)
Offline Austin
« on: April 24, 2015, 08:53:18 PM »
All I can say is Wow. What a great experience. Today I got my title and tags so naturally I drove my 3a from work (where I have been fixing it up) to my house, about a 25 mile trip. I took the state highway with a speed limit of 55. I felt very comfertable doing 40 - 45 MPH. I dont think I need to go any faster then this, as I was enjoying life to the fullest. Naturally, a few people get * off and flip the bird, but most people just smiled and waved. I have antique tags so there is no inspection needed, and my insurance costs $40 every 6 months. Not a bad deal at all. I also have to mention that the jeep does great aound town. The max speed in town is 35, very easy for the 3a to pull off. If you dont have a old jeep you should really consider getting one. They are extremely simple and a pleasure to drive!
Offline corpsman
Re: First Time On The Road
« Reply #1 on: April 24, 2015, 11:37:14 PM »
congratulations!  glad you got her on the road.  could you imagine what would happen if you tried to take one of those on the Interstate?  ha!
1952 M38
Offline JeepFever
« Reply #2 on: April 24, 2015, 11:41:25 PM »
All I can say is Wow. What a great experience. Today I got my title and tags . .
All I can say is Wow. What a great experience. Today I took my Willys on a back-roads drive.  I love this time of year!! Grass and fields are green again,  flowering and budding trees . . . so beautiful.
20+ years since my first time on the road,  and it is still an exhilarating experience !!
No "birds" on my ride,   just a couple other "single finger" shots at me  - >  thumbs up.   :)
Austin,  it will never get old,  you will always enjoy cruising in these beasts.  :)
Offline Austin
« Reply #3 on: April 25, 2015, 06:52:33 AM »
I want  to take a ride down skyline drive this afternoon.  Hopefully the rain holds out for me. Just my luck. As soon as I get this raod worthy, we have a week of cold rainy weather.
Offline Austin
« Reply #4 on: April 27, 2015, 06:56:10 AM »
Iv been driving it around all weekend. I put over 100 miles on it. Only broke down twice (two simple fixes)  first it just died after I filled the gas tank. Took a few minutes to figure out  but i determined that it was becuause the gas tank was not vented. Other other time my clutch went to the floor. That was because the linkage came out, so I replaced it with a nut and lock washer. The only other problem I have is my rear axle leaks oil like a sive. Not a big problem while in driving, but when I stop I have to smell that gear oil cooking on my exhaust. Im going to try to find a kit and rebuild next weekend.
« Reply #5 on: April 27, 2015, 01:27:24 PM »
That's great.  Congratulations.
Where on the differential are you losing the oil?  Front? Back? Bottom?  All?
Offline Austin
« Reply #6 on: April 27, 2015, 08:26:49 PM »
It looks like the oil is leaking on the front where the drive shaft connects.
« Reply #7 on: April 27, 2015, 10:32:50 PM »
That is a fairly common leak point.  If the seal surface on the yoke is grooved, you may need to add a speedi-sleeve to the yoke and replace the seal.
« Reply #8 on: April 30, 2015, 12:00:53 PM »
Tim hit the nail on the head on the yoke being grooved.  My yoke was grooved also and i lived with it for about a year putting off the repair.  When I got around to putting the speedi sleeve in, I wish I had did it sooner.  It is a super easy fix that doesn't take very long at all and you no longer have gear oil being slung all over the bottom of the jeep.
« Reply #9 on: April 30, 2015, 12:54:25 PM »
Tim hit the nail on the head on the yoke being grooved.� My yoke was grooved also and i lived with it for about a year putting off the repair.� When I got around to putting the speedi sleeve in, I wish I had did it sooner.� It is a super easy fix that doesn't take very long at all and you no longer have gear oil being slung all over the bottom of the jeep.
I�m with you Mark.� I put this off mainly because I had a hard time spending that kind of money on a little steel disc.� But it does solve the leak problem.� I've now installed a sleeve at all four positions on two different Willys.� �I should try to figure out how to invest in this company. :D
This was the cheapest guy I could find at the time�
http://www.ebay.com/itm/351201941913?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Here are a few photos of what to look for, and the process. Scroll down about 1/3 of the page.
http://www.cj3apage.com/cgi-bin/3Ayabb26/YaBB.pl?num=1364925701/75
« Last Edit: April 30, 2015, 12:55:08 PM by athawk11 »
Offline Austin
« Reply #10 on: May 04, 2015, 07:06:24 AM »
That doesnt look bad at all.  Do I have to use any sealer or gasket makerial on that sleve?
« Reply #11 on: May 04, 2015, 02:20:16 PM »
It is recommended to use a sealer between the sleeve and the yoke.  I used Permatex 2.
You will also want to use Permatex 2 to seal the splines between the output shaft and the yoke.  This is also a leak point.
Offline Austin
« Reply #12 on: May 05, 2015, 07:17:15 AM »
Tim, while im thinking about it, I have another question. My 3a jumps out of second when I take my foot off the gas. Still drivable, just a pain when I want to use 2nd gear to go down a hill. Is there a simple fix that doesnt involve a trans overhaul?
« Reply #13 on: May 05, 2015, 05:19:33 PM »
Austin,
Popping out of 2nd gear is a pretty common affliction on the T-90 transmission.� The internet is awash with this issue.�
I just got done fighting this same fight.� It generally means you have some worn out parts in the transmission.� It could be one part, or a combination of a few different parts.
I fought through this issue in my current build thread.� If you want to know what I ended up doing, here is a link to the start of my troubles.� It goes for a couple pages, but I did end up fixing the transmission.
It starts here about half way down on page 14 and trickles through to about page 17...
http://www.cj3apage.com/cgi-bin/3Ayabb26/YaBB.pl?num=1364925701/195
« Last Edit: May 05, 2015, 05:21:17 PM by athawk11 »
Offline Austin
« Reply #14 on: May 05, 2015, 08:50:55 PM »
Thanks for that info Tim. I keep hearing about Brass Bushings. One of my customers told me he has some new bushings machined from a higher quality brass. Its nice to see how everything looks before you go in. I will probably rebuild the trans when it starts getting cold out.
