Author Topic: Carter W-O Rebuild question  (Read 9067 times)
Offline Mudviper
« on: March 18, 2016, 12:29:45 PM »
Was in the middle of rebuilding my Carter W-O and noticed something different about mine that is not in the picture of the Carter W-O of the instructions I was going by. In the picture on the instructions on the Main Body there appears to be a tube sticking out that goes from the Main Body to the Throttle Body. When looking at my Main Body there isn't a tube on it. Does some of these carbs have it and some don't. It seems like a key part to the assembly. I attached pictures to show what I mean. The part circled in blue is the tube. Also in the rebuilt kit there is no spacer included in it that goes between the Main Body and Throttle body. My carb didn't have one when I took it apart, is that not used anymore when you rebuild them?
Offline Mudviper
Re: Carter W-O Rebuild question
« Reply #1 on: March 18, 2016, 12:30:31 PM »
Here is a picture of my Main Body without the tube
« Reply #2 on: March 18, 2016, 01:38:55 PM »
Mud,
I had the same question a few years ago, but couldn't find the thread.  I think it may have been on the old 3A forum, which is long gone.  I freaked out enough to add a small piece of tubing in this location, only to find I wasted my time.
You're good.  There are slight differences on the bowl portion of these things.  I've rebuilt several Carter WOs at this point, and only one has the short tube shown in the above photo.
Offline Mudviper
« Reply #3 on: March 18, 2016, 01:45:07 PM »
Thanks Athawk... Before rebuilding the carb it was pouring gas out of the outside and inside of it, so thought that might have been the reason why. What about the throttle body spacer? Is that needed or am I ok with just using a the double gasket?
« Reply #4 on: March 18, 2016, 02:25:35 PM »
 I wouldn't be confident enough to leave the spacer out of the equation.  There is a lip on the bowl portion of the Carter.  Without the spacer, I'm not sure if the gaskets would be enough to tighten it to the throttle body, though I have never tried it that way.
Offline Mudviper
« Reply #5 on: March 18, 2016, 05:51:07 PM »
There is probably no place that sells just the insulator. Tried googling it and having no luck
« Reply #6 on: March 18, 2016, 06:54:10 PM »
Just noticed you're from Flint.  We're sure seeing a lot of news about you community.
Send ScoutPilot a PM.  He is a professional rebuilder.  I have purchased a number of individual Carter WO parts from him.  He is a very safe and reputable person to deal with.
Offline Mudviper
« Reply #7 on: March 18, 2016, 07:57:50 PM »
Yeah it is never a dull moment in this town. If we are not shooting one another we are trying to poison each other with water..lol.
Well get with ScoutPilot.. Thanks
« Reply #8 on: March 19, 2016, 06:32:42 AM »
[size=12]Hey Mudviper. Just saw this post. The tube your curious about is a vent. In later designs it was determined that the necessary venting action could be accomplished without it. As far as deleting the insulator goes, it is necessary for precisely the reason it is called an insulator. It and the two gaskets keep the heat in the bowl/main body section so the fuel in the bowl, when called for, is of a proper temperature to atomize correctly in the airstream going to the cylinders. Proper fuel temperature is also why there is a heat riser valve in the exhaust manifold. To quickly bring the fuel in the bowl up to a proper temperature. However, if stuck open, that heat will cause the fuel in the bowl to boil and flood the carburetor much as you have described.[/size][/b]
Offline Mudviper
« Reply #9 on: March 19, 2016, 09:35:36 AM »
Thanks Scoutpilot.. now where do I get one of these isulators? It doesn't seem like anyone cares these.
« Reply #10 on: March 19, 2016, 02:28:05 PM »
[size=12]PM your address. I�ll send you one.[/size]
« Last Edit: March 19, 2016, 02:28:49 PM by scoutpilot »
Offline Mudviper
« Reply #11 on: March 19, 2016, 04:30:43 PM »
Thanks Scoutpilot.. been trying to locate one around me with no luck yet
« Reply #12 on: March 19, 2016, 08:31:20 PM »
[size=12]Your welcome. One will be on it�s way Monday.[/size][/b]
Offline Mudviper
« Reply #13 on: March 20, 2016, 11:47:45 AM »
Thank you. What do I owe you for one?
« Reply #14 on: March 21, 2016, 04:45:19 AM »
[size=12]Nothing. These seldom break and are rarely lost by PO�s. I�ve got plenty.[/size][/b]
