Author Topic: block heater...?  (Read 2879 times)
Offline Trenton
block heater...?
« on: November 24, 2015, 02:31:22 AM »
ok so centre of the right side of the pic, rearward of the thermostat housing theres what i think is a block heater. has two electrode posts sticking out the top. anyone recognize it? id like to find a cord or plug for it. living here in southern B.C. its cold for a long time over the winter, be nice to be able to fire her up even if she's sitting outside.
1950 CJ3A... Work in progress
Re: block heater...?
« Reply #1 on: November 24, 2015, 07:56:31 AM »
That's called a head bolt heater. They are used as a stud and have a extension that protrudes down into the coolant. Pretty slick, but are easily damaged . They also used the same thing but with a threaded soft plug that presses into the block soft plug hole. I have one that still works great in my '46 Chevy. John
Offline BMIC
  • Weekend Mechanic
« Reply #2 on: November 24, 2015, 09:27:33 AM »
I took one out when I did my rebuild a few wears ago. I never did test it to see if it worked and must have tossed it after the build was complete. I may rummage through old parts to see if I still have it.
Ryan-M you must have one kicking around in your "tween" parts bin.
Offline Jeff_M
« Reply #3 on: November 26, 2015, 06:54:27 PM »
Interesting, I never knew it had a heater of any sort.  My grandfather used the Jeep (or that motor) for plowing for quite a few years but kept it in an unheated garage, he must have thought the 6v system needed some help in the winter, which I suppose it would have.
