Author Topic: Fan shroud screws  (Read 3449 times)
Fan shroud screws
« on: November 15, 2015, 06:44:31 AM »
Since I was not there when my cousin removed the fan shroud, I have no idea what fasteners to use to mount it to the radiator, does anyone here have the screw specs?
Kirk
Re: Fan shroud screws
« Reply #1 on: November 15, 2015, 07:14:31 AM »
Screw, pan head, No. 8-15 x 3/8"
Be careful, these screw holes are REALLY close to the core. If the screw is too long it will poke a hole in a tube.
« Reply #2 on: November 15, 2015, 08:17:36 AM »
Thank you Bob, that was my worry...
« Reply #3 on: November 18, 2015, 11:10:01 AM »
I'm pretty sure I ground the sharp tips off the screws before I put them in...
I had read about a couple of punctures from screws that were just a little too long...
« Reply #4 on: November 18, 2015, 01:25:45 PM »
Randy thanks for the tip and the pictures, I did in fact get some new screws and ground the tips off. Acually quite a bit of the screw. Then I added blue loctite before screwing them in slowly.
Fingers crossed no leaks... Engine should be running in frame week after next!
« Reply #5 on: November 18, 2015, 02:29:53 PM »
Good work as always!
We want to hear it run...... :)
