Author Topic: Wrong brake shoes for a 51, different year axles??  (Read 9681 times)
Re: Wrong brake shoes for a 51, different year axles??
« Reply #15 on: May 04, 2015, 10:35:48 PM »
You're right.� I think a made an assumption that the 27 arrived on the scene the same time the 44 shows up.
Man I hate when assumptions are made...especially by yours truly.
That said, Jersey may have a 41 or 44.
« Last Edit: May 04, 2015, 10:37:24 PM by athawk11 »
« Reply #16 on: May 05, 2015, 06:11:14 AM »
M38's have a 25 and a 44 which is why I questioned it in the first place. I'm not even really sure what the true difference is between a 25 and 27 is anyways. Axles are a little thicker on the 27 maybe? I know the differentials are not interchangeable but again I'm not really sure why.
« Reply #17 on: May 05, 2015, 03:45:19 PM »
I replaced the spider gears in my 25. Walck's sells this kit as interchangeable between the 25 and 27.  I wonder if the inner axle shafts are better, or the ring and pinion has changed on the 27.
There are so many other fun things I would rather do, but I guess it's time for a little axle research. :P
