Author Topic: Rear Spring Repair  (Read 4847 times)
Rear Spring Repair
« on: December 29, 2013, 02:12:03 PM »
Based on my earlier post about spring curvature and the lack of response I figured this would be a good topic to explore some more, and I found out quite a bit.� So here is the background:
About 5 years ago I was working on the suspension on the jeep, replaced the front springs with new and left the original rears in place.� However I had the typical Jeep lean to the driver side, about 1.5 inches.� Not able to afford the new springs at the time I found a set of 2 secondary springs at 4wheel parts in Salt Lake.� I installed one on the driver side, that eliminated the lean and its been good for 5 years, now this year the passenger side decided to lean, and it was down about 2 inches.� So I installed the other secondary that I had on the pass side.� Along the way I had to find new spring clamps as mine were shot and I wanted to know the details on the spring settings.� I bought the clamps at Husky Spring in Minneapolis, www.huskyspring.com.� They were very helpful and gave me copies of the Willys spring page from the Dayton spring catalog.� I'll get them to pascal so he can post in the right spot on the page.� But here is the detail.
Willys front springs for 2A and 3A-
8 leaf 3 1/4 inch free lift (no weight)
10 leaf 3 1/2 inch free lift
Rear Springs:
9 leaf 4 3/4
11 leaf 4 3/8
All measurements are from a straight edge running through the center of pivot points to the top of the bolt that holds the spring pack together.�
On my project I had about 2 inches of sag to remove and no post Christmas funds for new springs.� I pulled the spring pack and took it apart, removed the lower three leaves and replaced with the new secondary.
Here is a picture of the new clips, part number HC-1
This is the spring pack with the new secondary installed, one thing that did change is that the secondary reached the spring pack, the arch increased by 3/4 inch however there were no issues with lining up the shackles.
This is a picture of the new clamps, installation is easy, clamp the spring pack tight with both clamp halves installed, hammer the tabs in place.� Nice and tight however some adjustment and fiddling is needed to get them just right.
http://rs1089.pbsrc.com/albums/i356/banjo19/jeep9_zpscf084163.jpg~c100
So here is the jeep, level again.� This repair cost less the $100.00, its not a restoration, but I suspect there are a few of us out there that can use this option.� Husky also sells the complete spring pack for the jeeps, however the price they quoted me was quite a bit more than Walcks price so I chose to not mention it.
Hope that was a little help.
« Last Edit: December 29, 2013, 02:38:39 PM by Gunslinger »
Offline Lee
  • Will-is enthousiast
Re: Rear Spring Repair
« Reply #1 on: December 29, 2013, 08:53:38 PM »
Gunslinger, very interesting bit of info, thanks for posting.
Lee ;)
Offline johnnybravo
« Reply #2 on: March 20, 2014, 09:35:29 PM »
I have a parts jeep with that type of rebound clip, but most I have seen are different.� I have equipment down at this time so I cannot post a photo but I have photo posted on the cj2a page in "Wanted Section" under "SpringWraps".  I purchased from Pete DeBella's.� �
« Last Edit: March 20, 2014, 09:45:56 PM by johnnybravo »
Offline fasilpereira
« Reply #3 on: February 16, 2024, 12:19:10 PM »
Dear friends,
If someone has a copy of the Jeep Spring Catalogue mentioned on this thread, please share it with me by email fasilpereira (at) yahoo (dot) com
I’m about to repair my springs and that info would be very helpful.
Thank you,
Fabricio
