Author Topic: Windshield vent gasket  (Read 4717 times)
Offline Jesse
« on: July 07, 2014, 05:17:21 PM »
Alright well over in tech talk we starting talking about driving in the rain, etc.
My problem is the windshield vent gasket. How are you guys sealing yours up? I bought one from Walcks and it's pretty much a piece of rectangular foam. Lets water in like crazy.
Is there a gasket that seals up properly? I was thinking about just running some soft rubber tube along the inside edge of the cover or something.
-Jesse
Re: Windshield vent gasket
« Reply #1 on: July 15, 2014, 09:05:40 AM »
Is your vent closing tightly on the gasket? If both surfaces are smooth and straight without any bumps or divots the foam should not be leaking water....
« Reply #2 on: July 15, 2014, 12:24:37 PM »
I bought a heavy rubber/foam seal from Home Depot.� 1/2" tall x 3/4" wide with a self stick backing, installed on the inside edge of the door.� It's not OEM, but it looks nice and seems to seal up pretty good.
« Last Edit: July 15, 2014, 12:25:14 PM by athawk11 »
« Reply #3 on: July 15, 2014, 04:59:00 PM »
I had to put a couple spacers (washers) between the hinge and the windshield frame, otherwise the top of the vent seal hit first and would hold the vent open about 1/2" at the bottom.....lifting the hinge side away from the frame allowed the vent to close more evenly....
« Reply #4 on: July 15, 2014, 06:30:34 PM »
Jesse, I have a repro windshield which as far as I can tell, has a problem.� If you sight along the vent and vent opening, the vent is flat but the opening has convex sheet metal along the top and bottom edges of the opening.� There is no way to make the vent come down flush with the opening unless I was willing to grind down the convex area (I was not).� So, I just built up the edges of the vent with foam and called it good.� Rubber tubing would get you there too.� Why the maker would do this is beyond me.
« Reply #5 on: July 16, 2014, 10:28:44 AM »
I also have a repro windshield and I had to "massage" the vent opening a little bit in order for it to fit flush with the gasket installed.  As best as I can remember, the lip on the windshield was too tall and and at an odd angle.  I took a grinder and shaved off some of the lip and a pair of flat vise grips and adjusted the angle.
It wasn't a major operation, but something you want to do before paint.
Offline Jesse
« Reply #6 on: July 16, 2014, 03:38:41 PM »
Hmm. I'm thinking about the adhesive rubber option. The door shuts pretty tight. I guess the foam in there keeps it from rattling but I don't see how it would ever stop water.
Thanks guys,
-Jesse
