Author Topic: Mini Project on ODie  (Read 12075 times)
« on: July 27, 2015, 11:49:33 PM »
Just wanted to share some pain with my Willys brethren.�
I've been chasing a rear main leak for some time now. I've done the Sneaky Pete approach 3 times in this year alone.� With little success, I've finally pulled the trigger...and pulled the engine.
While out, I also decided to do a ring job.� I found broken top rings on #3 and #4 pistons.
This is a 1944 GPW engine that was probably sold to a parts house by Ford following the end of WWII.� It has never had a rebuild.� It still has standard size pistons and the crank and rod journals are still within spec.� I have no idea when this engine was replaced, thus no clue how many miles it has on it.� My guess is, very few.� Since under my control, it has about 4000 miles added to it.
I've done most of the repairs and I'm nearly ready to put it back in.� Pulling an engine is a lot of work.� No wonder I tried to avoid it.
« Last Edit: July 27, 2015, 11:52:15 PM by athawk11 »
Re: Mini Project on ODie
« Reply #1 on: July 28, 2015, 05:49:46 AM »
[size=12]I will commiserate with you. Two motors out and two in in two years.[/size][/b]
Offline RedWilly
  • Flat Fender
« Reply #2 on: July 28, 2015, 10:17:42 AM »
Hey Tim, I am curious, what did you have for compression on #3 and 4?
Thanks
Glen
Glen
49 CJ3A
« Reply #3 on: July 28, 2015, 10:55:46 AM »
Hi Tim,  How did you know those rings were broken?
Also, how did the seal install go?  What could you do with the engine out that you couldn't do before?  You used that same rope seal?
« Reply #4 on: July 28, 2015, 03:19:48 PM »
Rick, I have been following your engine issues.  I know you feel my pain�and it�s my pain on steroids.
Glen,  The last time I checked was last year before the FCT.  Compression was in the High 70s, so I knew something was a little tired.
Tom,  I really didn�t know I had broken rings until I pulled the pistons.  Because of my low compression readings along with a leak down test, I made a semi�non--educated guess that they were worn or broken.
The seal installation went well.  I am using the rope seal.
The disadvantage you have when installing the seal with the engine in place�  You need to pull the new seal over the crank shaft.  This is difficult enough because the Sneaky Pete style tools don�t work very well.  Added to this, you�re on your back with poor lighting, and very little space to maneuver.  It�s nearly impossible to cut the seal to the proper length once you have it pulled over the crank.  And through it all, you have oil constantly dripping on your face.
The advantage to doing the seal without the crankshaft in the way�You can properly pack the seal in the channel and you have added room to cut the seal to the correct length.
Again, I was willing to try the Sneaky Pete approach because of the added effort required to pull the engine.  But as you know from the SDR, I was embarrassed by this failure�plus I�m tired of wiping the oil splash back from the underside of my Willys.  I don't mind wiping the mud and dirt off.  It comes off way easier than oil. ;)
Offline Lee
  • Will-is enthousiast
« Reply #5 on: July 28, 2015, 07:31:36 PM »
Tim, your broken rings concern me, inspect your ring grooves carefully. I have seen this before, I have found the ring grooves in the piston to be worn (top to bottom of the groove).
Good luck with repairs, Lee ;)
« Reply #6 on: July 28, 2015, 11:56:25 PM »
Lee, I did inspect them after cleaning them.  They looked to be crisp and had sharp edges, but I didn't measure them.  The #2 ring was interesting though.  It was a three part ring.  I haven't seen rings like this before.  No, I'm not confusing it with the #3 ring.  It was a traditional 3 part set up. I haven't seen a ton of rings, so maybe this isn't that unusual.  This was the combination found in the #2 position.
« Reply #7 on: August 02, 2015, 07:48:04 PM »
Engine is back in.
Initial test start... Running like a Swiss watch.  I'm tuckered out for tonight, but tomorrow I'll reinstall the grill, then take it for a run to see if the rear main leaks.  I'm in a freakin good mood! :)
« Reply #8 on: August 02, 2015, 08:10:16 PM »
cool [smiley=thumbsup.gif]
« Reply #9 on: August 02, 2015, 08:52:54 PM »
Wow...Tim you are the enginemiester...and transmissions too..
« Reply #10 on: August 03, 2015, 12:44:55 PM »
� I'm in a freakin good mood! :)
Me too pal!!
« Last Edit: August 03, 2015, 12:45:51 PM by MC51986 »
« Reply #11 on: August 03, 2015, 12:52:13 PM »
Lol Tim.  I know how I feel after I do an oil change or R&R an e-brake cable...I can just only imagine how happy you must feel right now.  If I had half the talent you do, I would die one happy camper!
That said, don't get bummed if/when a drip comes back.  I think that is just the nature of the flatfender.
« Reply #12 on: August 03, 2015, 03:01:29 PM »
Thanks for the encouragement my friends! :)
Tom, I expect some dripping...just hoping it's not torrential like it was in South Dakota. :-[
« Reply #13 on: August 03, 2015, 08:36:42 PM »
You are talking Model A stuff here! Actually I have yet to find a single gasket between the engine and transmission....
« Reply #14 on: August 04, 2015, 05:17:12 AM »
Glad you got your rig back together again. I believe that these Jeeps will test your patience for sure! Once you get rolling and that cool air blowing through your hair your frustrations will disappear!
