Author Topic: Will this be a problem?  (Read 2674 times)
« on: December 17, 2013, 06:49:43 PM »
Thinking about what I want to do with the fitty-five Chevy. I have access to a set of 4.57 gears for the original rear end. If I do decide to make it 4wd, I can get 4.56 gears for the K20's front axle.
Will the .01 difference be a problem if I use the 4wd?
Offline johnrb3b
    • Jeeps and stuff
Re: Will this be a problem?
« Reply #1 on: December 17, 2013, 11:35:36 PM »
No.
That's more than the difference you'll get with unequally worn tires.
If you want to be a math fanatic, you're doing it the right way, putting the deeper gears in the back so the front axle will be pulling a bit compared to the rear.
But
In reality the difference is so small the tires will swamp it.
« Reply #2 on: December 18, 2013, 07:58:39 AM »
Ok, thanks!
Offline gmcjr
« Reply #3 on: December 19, 2013, 10:08:13 PM »
Most of the factory 4x4 vehicles have that or more of a difference between the front and rear
Gary in N. Texas
51 CJ-3A (old Trusty)
52 Ford 8n (ugly duckling)
46Farmall B (old Rusty)
18 Wrangler Jk
Offline duffer
  • Just old
« Reply #4 on: December 20, 2013, 10:19:18 AM »
Yep.  A lot of examples including the D25/D44 4.09/4.10 sets.  Is the rear axle on that the drop-out style?  I didn't have too good a luck with those not spitting gear teeth out on the street.  On the flip side, very easy to set up.
Nate, what are your plans for the rest of it?  I would very much like to build a 46 3/4 ton Chev using my present 3B engine, SM 465, and NP 203/205 doubled T case.  Probably just going to use D44/D60 axles under it but maybe 60's on both ends.
John, Bozeman, MT
« Reply #5 on: December 20, 2013, 12:26:16 PM »
If drop out style means that the yoke and carrier all come out in one piece like a ford 9" rear, then yes.
So far it consist of a 350 sbc, 700r4, NP208, stock rear axle, and the K20 front axle (GM 10 bolt). I don't need a radical 4x4. I just want to build it into one and use it to bring engines to engine shows and maybe do a little drag racing...  :o I know, 4.56s are probably not the best gear choice, but it will get off the line fast and with the overdrive, it will have a final ratio of 3.12 which isn't horrible. And if I add a super charger...  ;)
Offline Bill
« Reply #6 on: January 13, 2014, 10:58:10 AM »
Look for a set of CUCV axles any of the pickups will have 4.56 front and rear, most have a least a rear locker.
1952 USAF M38
