Author Topic: Why does everything have to be a fight ?  (Read 3455 times)
Offline Kenny_Kustom
« on: April 15, 2013, 08:58:55 AM »
The proper 3a rad shroud didn't fit my 2a rad ( in my 3a) So, i dropped the $500 on the 3A rad from walcks.
Put in it, and now i get to re do the alternator mount !! YAY!!! �>:( >:( ::)
I guess its not all bad, as the alt was about 2" too far forward to begin with.
I should have just left this whole thing alone, and just driven it the way it was...
Re: Why does everything have to be a fight ?
« Reply #1 on: April 15, 2013, 02:27:15 PM »
Come on Kenny,
What would be the fun in just driving them?? ;) �In all honesty, it can sometimes be a bit frustrating. �That's what makes research and repairs so interesting on these old beauties. � Lot's of interchangeable parts and modifications over 60 years. �
On mine, I was going to fix the brakes, patch a couple holes in the side panels, then spray a little ratttle can paint...
Next thing I knew, my Willys was in hundreds of pieces scattered all over my garage.
« Reply #2 on: April 15, 2013, 05:15:39 PM »
You may have noticed that we all seem to have cute affectionate names for our jeeps.  This is actually a coping mechanism we use to project on these vehicles the behavior and attributes we wish them to have.  Mine is called Triple X for the simple reason that I had to do just about everything on it three times!!!
Soldier on, it's worth it.
Offline Macgraham
« Reply #3 on: April 15, 2013, 06:17:56 PM »
That's why we do Jeeps cause the fun never ends. :P ;D :'(
« Reply #4 on: April 15, 2013, 08:59:11 PM »
I have done ground up builds on jeeps before. All either yj's or tj's. Nothing this old.
I bought this one as a restored jeep. My intentions were to not do anything to it....  ::)
« Last Edit: April 15, 2013, 09:00:29 PM by Kenny_Kustom »
« Reply #5 on: April 16, 2013, 06:07:15 AM »
That's what happens you start modifying things!  ;)
Offline johnrb3b
    • Jeeps and stuff
« Reply #6 on: April 16, 2013, 09:34:33 AM »
My intentions were to not do anything to it.... �::)
Famous last words. ;)
I bought mine to just drive.
Then I found a few things that needed fixed.
Then I decided I needed to add a couple things.
Then . . .
But I've done nothing that kept me from driving it.
I won't be doing a tub-off restoration.
Famous last words. �;D
« Last Edit: April 16, 2013, 09:35:19 AM by johnrb3b »
« Reply #7 on: April 16, 2013, 09:47:26 AM »
That's what happens you start modifying things! �;)
That's the thing!! I have no problem with the fight, when its me, changing from stock.
BUT I WAS PUTTING IT BACK TO STOCK!! Lol.....
Yes the alt isn't stock. But I need 12volts.
Oh well. Ordered the alt bracket and proper adj bracket.
« Reply #8 on: April 22, 2013, 06:52:51 PM »
My latest endeavor.
The oil line from the filter to the front cover.
Came off the filter housing ok.
Looks like someone brazed the other end to the cover!!!! >:(  :'(
« Reply #9 on: April 22, 2013, 07:50:17 PM »
There is a hex fitting that is brazed onto the cover from the factory. The hose should unscrew from that with a brake line type flare fitting. It should be a 7/16" wrench.
« Reply #10 on: April 22, 2013, 09:04:13 PM »
Gotcha !! It was 10 to 5, and i just had a quick look before going home. I'll check it in the am !!! Thanks !!
« Reply #11 on: April 23, 2013, 08:18:45 AM »
YUP.. Bang on. Got it out. The hose pretty much fell apart in my hands. I need to be able to spend some solid time on this thing. I end up just getting 20 min here and there in between other cars that come in.
