Author Topic: balancing tires  (Read 5065 times)
Offline Carls_jeep
balancing tires
« on: January 10, 2012, 05:18:38 PM »
Here's a good example of why you should have your tires balanced.
I bought four new tires and tubes and two of them needed a lot of weights to make them balanced. If two out of balance tires such as these are on the front end it could easily cause a loose front end to have the weath dobble, I mean, the death wobble.
Re: balancing tires
« Reply #1 on: January 10, 2012, 07:02:42 PM »
That's a good looking tire, Carl.  Can I ask what brand, model, and size they are?
Offline Carls_jeep
Re: balancing tires
« Reply #2 on: January 10, 2012, 11:10:01 PM »
It's a 6.00x16 and I got four of them and tubes from Wallace Wade Specialty Tires.
Offline Jesse
Re: balancing tires
« Reply #3 on: January 11, 2012, 01:43:01 PM »
I'm not going to get my tires balanced, life doesn't ruin itself you know.
-Jesse
Re: balancing tires
« Reply #4 on: January 11, 2012, 05:07:08 PM »
Looks like my rims -  ;D -I was surprised to see that much weight on my first set of tires for my 53 wagon but it sure helps with the ride to have them running true.
BTW - Wallace Wades shop is right around the corner from my office in Dallas. Pretty cool place for a tire depot! I'll be getting my new set of NDT from him as well on my CJ. I am going with the 7.00-16.
George
Offline rocketeer
  • Support Our Troops.
Re: balancing tires
« Reply #5 on: January 11, 2012, 08:26:59 PM »
Static or dynamic balance?
Offline calvinhunt
Re: balancing tires
« Reply #6 on: January 12, 2012, 02:03:44 AM »
I'm betting Carl had them dynamic balanced (seeing the one small weight separated a bit from the bigger weights).  When I was young I worked in a service station where we mounted and balanced tires.  We only had a static bubble balancer and I never saw weights separated till using a dynamic balancer much later.  However, I must say that you could really get a tire well balanced if you took your time and worked at it till you got the bubble exactly centered.  My fussiest customer was my dad.
Calvin
Santa Clara, Utah
Offline rocketeer
Re: balancing tires
« Reply #7 on: January 12, 2012, 09:17:28 AM »
Calvin, the correct way to static (bubble) balance is with the use of 4 equal weights spaced, in pairs, about 1/4 of the way around the wheel apart to start. You then move the pairs around until the wheel balances. You may have to swap the 4 weights for a set of heavier or lighter ones depending on how far apart they need to be to balance the bubble, always trying to maintain a distance of about 1/4 of the wheel or a little less. When the wheel balances you mark the tread with chalk, flip the wheel over and tap on one weight at each mark. You then set the wheel back on the balancer and set the remaining 2 weights back on the rim near the chalk marks. Move them a bit as needed to achieve final balance and tap them in place. In a static balance situation there should always be 4 weights of equal weight, 2 per side, and equally spaced apart, never together. That's the only way to acheive a static balance without disrupting the dynamic balance any more than it already is. Dynamic balance is always preferred.
Carl, can you imagine the death wobble that baby would have created?
« Last Edit: January 12, 2012, 09:25:45 AM by rocketeer »
Re: balancing tires
« Reply #8 on: January 12, 2012, 09:41:39 AM »
Discount tire in Bedford did mine - dynamic -
George
Offline Carls_jeep
Re: balancing tires
« Reply #9 on: January 12, 2012, 01:12:14 PM »
They were dynamic balanced. When I saw those weights, which were more than on any of the other three tires, I knew how bad that would have been on a front wheel without them. Even with a tight front end it could have still caused a wobble since nothing is as firm as a rear fixed axle. I do have it on the rear axle.
Re: balancing tires
« Reply #10 on: January 12, 2012, 01:34:14 PM »
No doubt that balancing is the way to go, but...do you really feel it makes much difference on a vehicle that never sees over 30-35 mph?  Don't get me wrong, I would never suggest not balancing, but am wondering if we would really notice if they weren't balanced and if it could set-up the dreaded "death wobble".  It would be an interesting experiment to drive "unbalanced" and to then drive "balanced" to see what kind of difference there is at, say 35 mph.
Offline Matto
Re: balancing tires
« Reply #11 on: January 12, 2012, 04:27:26 PM »
I never really thought about tire RPM before this thread and was surprised by how fast it actually is. A standard 16x6 NDT tired is about 27.75" in diameter which gives it a cirumference of about 87.162". At 35 MPH this tire will travel 3080' which would be about 424 RPM or about 7 revolutions per second. The need for accurate ballancing becomes pretty clear when you look at it from this perspective.
Math was never really my strong point so if anyone wants to dispute these numbers please feel free to do so. I will not be the least offended. Carl has already had to correct me once today for not reading a post all the way through.
Matt
Re: balancing tires
« Reply #12 on: January 12, 2012, 04:52:15 PM »
I think your math is solid, the numbers don't lie.  Seven revolutions per sec...who'd a thunk it?
Offline Carls_jeep
Re: balancing tires
« Reply #13 on: January 12, 2012, 08:45:13 PM »
The older dynamic balancers that spun them up on the car went pretty fast. I can remeber that if I didn't dig all the rocks out of the tread it may throw them out at me. The later ones that you mounted the tire and rim on still spun them fairly fast but the newer balancers don't spin up very fast at all. In fact the first time I saw one in action I didn't think it would do a good job but it did.
Yes, a tire out of balance as much as that tire on a loose front end would probably wobble so much it may be very dangerous.
Offline rocketeer
Re: balancing tires
« Reply #14 on: January 12, 2012, 09:09:46 PM »
The old dynamic "spark" balancers were capable of 100mph. The newer ones run at about 55mph. I always balanced tires at 75mph in the old days.
