Calvin, the correct way to static (bubble) balance is with the use of 4 equal weights spaced, in pairs, about 1/4 of the way around the wheel apart to start. You then move the pairs around until the wheel balances. You may have to swap the 4 weights for a set of heavier or lighter ones depending on how far apart they need to be to balance the bubble, always trying to maintain a distance of about 1/4 of the wheel or a little less. When the wheel balances you mark the tread with chalk, flip the wheel over and tap on one weight at each mark. You then set the wheel back on the balancer and set the remaining 2 weights back on the rim near the chalk marks. Move them a bit as needed to achieve final balance and tap them in place. In a static balance situation there should always be 4 weights of equal weight, 2 per side, and equally spaced apart, never together. That's the only way to acheive a static balance without disrupting the dynamic balance any more than it already is. Dynamic balance is always preferred.
Carl, can you imagine the death wobble that baby would have created?
