I had a few questions about my steering so here are some more photos....
It's in winter mode now so the snow plow is installed. The frame is boxed from the round crossmember forward and three tubes are welded in placed for the steering box mounting bolts. The top bolt is above the frame and has that tripod to support it. The box is forward as far as possible and the front bumper is bowed up slightly to fit the box.
Here is the steering column at the firewall. This column was in another Jeep, I would really like to shorten it so it doesn't extend so far out for this application. The stock worm gear was cut off the shaft then the bottom was bored out to 3/4". Then a splined shaft slid into the original shaft and was welded on. I made a plastic bushing to support the shaft in the end of the column. I think Advance Adapters makes a bronze equivalent. All the steering shaft parts are Borgeson steering parts
http://www.borgeson.com/
Here is the steering shaft at the grill area. I have a 1" body lift so the steering shaft just fits. You can see the 1" spacer in this photo. The crossmember was dimpled to give enough space for the U-joint. The grill also has a slight bend in the sheetmetal so everything fits.
Here is the tie rod and drag link connected to the right knuckle of the CJ-7 Dana 30 front axle.
