Author Topic: '52 M38  (Read 171048 times)
0 Members and 38 Guests are viewing this topic.
Re: '52 M38
« Reply #270 on: February 26, 2015, 06:58:12 AM »
Looks good Ryan! Just round off the corners to you won't be slicing yourself every time you have to clean the distributor cap or points. ;)
« Last Edit: February 26, 2015, 06:58:29 AM by garage_gnome »
Re: '52 M38
« Reply #271 on: February 26, 2015, 07:17:46 AM »
A little more progress this week:
Windshield installed. Grill welting installed and hood squared up. 4 reflectors added. Spare tire mounted and installed. Jerry can strapped down, albeit incorrectly (How is it supposed to go anyways??). Crudely upholstered (by PO) back seat loosely set in place (really cool how it folds up....).
It's 5�F. Might as well go for a ride before work.
Offline Jeff_M
Re: '52 M38
« Reply #272 on: February 26, 2015, 07:51:27 AM »
Looks great, I really like the color.  And nothing like a clear new windshield to spruce things up, too!
Offline BMIC
  • Weekend Mechanic
Re: '52 M38
« Reply #273 on: February 26, 2015, 10:56:23 AM »
You did a fantastic job! What a contrast from page one of this thread to now....
Offline Bill
Re: '52 M38
« Reply #274 on: February 26, 2015, 08:09:55 PM »
very impressive!
1952 USAF M38
Re: '52 M38
« Reply #275 on: March 01, 2015, 08:20:28 AM »
Nicely done, love it
Re: '52 M38
« Reply #276 on: March 08, 2015, 02:12:37 PM »
Since I'm going to try and register this M38 as a regular passenger vehicle (as opposed to an "Antique") it'll need to pass a state inspection. I don't need to bring the vehicle to today's standards but if it was stock equipment when the vehicle was new it needs to be there. No seat belts? No problem...an M38 never had them. No wiper? Problem. I need to have one of those.
I've driven a topless flat fender a considerable distance in a rain storm. I can tell you that a wiper makes little difference. I spent more time wiping the inside of the windshield with my sleeve than the wiper did working on the outside of it. Oddly, the rest of me stayed surprisingly dry so long as I kept moving.
Anyways, a wiper will be all but useless to me except to pass the inspection. I really miss the days when as long as you left a 30-pack on the garage counter you where leaving with a valid inspection sticker. The condition of the vehicle was irrelevant. I don't have one of those guys anymore.
So today's task was rigging up a wiper. I tried using a spare Trico SF 616 vacuum I had laying around but couldn't get it to work - nor do I want to spend the money to repair or replace it.
Next up was one of those generic "universal" electric wiper motors. They are complete crap but for now it is operable. Here's how it went.
I wired a 10A fuse to the "ACC" terminal of the key switch. I used a bullet connector here so I can easily disconnect in the event I have to remove the windshield.
I snaked some rubber hose through the firewall and fished the positive wire through it and then through the hole in the side of the tub. Next, feed the positive wire through a length of steel brake line tubing. If you wait until after you bend the line it will be much more difficult (if not impossible) to feed your wire through it.
Next, bend the steel line to the proper shape. I used an original bent vacuum line to help get me started on the overall shape and then just jammed it into place. A new roll of masking tape makes a good tool for bending the line in nice even arcs. It can be removed for paint once it's all bent to shape. As you can see I still need to paint some of the hardware here too.
I filed the sharp edges off the end of the steel line and slid a length of heat shrink over the end of the wire and into the tube for added protection against any chaffing. I got a little carried away grinding ground points around where the motor contacts the windshield frame. I'll touch that up with paint later.
Then I slid a piece of rubber hose over the end, added a connector and attached the wire to the motor.
So now inside and out the electric wire is concealed by a set-up similar to what you would see with any vacuum wiper.
I have no hope that this wiper motor will even survive a rainstorm but as long as I can keep it dry until inspection time it should do the trick. I'm going to leave the passenger side alone. Worst case I'll install a hand wiper over there. At least I'd know that one will always work.
« Last Edit: March 08, 2015, 03:16:27 PM by Ryan_M »
Re: '52 M38
« Reply #277 on: March 08, 2015, 02:57:10 PM »
Very clever way to give it "the look".  I love it.
Re: '52 M38
« Reply #278 on: March 08, 2015, 03:18:23 PM »
I can't take credit for the idea as it's been done several times before (including Nate, I think). I just hadn't found any pics of it online.
Offline Jeff_M
Re: '52 M38
« Reply #279 on: March 08, 2015, 07:26:09 PM »
Very tidy job.� Why are you not registering it as an antique?� Insurance?  Tell you what:  If you can get that stickered after the way it was before it'll be quite an accomplishment.
« Last Edit: March 08, 2015, 07:28:48 PM by Jeff_M »
Re: '52 M38
« Reply #280 on: March 08, 2015, 07:41:04 PM »
I like to drive to work which often means parking on the street in downtown Bangor. It's an area heavily patrolled by the parking enforcement crew who dutifully issue tickets if you are in a 1-hour spot for a second more than 59 minutes. I routinely get tickets which is not a big deal but all the ticket guys know my vehicles.
Driving to work is a direct violation of the "Antique" registration affidavit they make you sign when you register. Hard to tell if it would ever be enforced but I don't like worrying about it. If I can get the M38 inspected then it's a non-issue.
I'd register the 3A as a regular passenger vehicle but then I couldn't legally display my snazzy 1952 plates - those really befuddle the ticket guys because they aren't in the system� ;D...but then they could easily have my Jeep towed and impounded for improper use....
« Last Edit: March 08, 2015, 07:41:18 PM by Ryan_M »
Re: '52 M38
« Reply #281 on: March 08, 2015, 07:43:08 PM »
I didn't use steel tubing. I ran the wires in the cotton loom using the stock clamps. Looks great Ryan!
Re: '52 M38
« Reply #282 on: March 08, 2015, 07:45:40 PM »
Nate - What do you have for wiper motor(s)? Seems there's only that one generic style available. Did you come up with anything more elaborate?
Re: '52 M38
« Reply #283 on: March 08, 2015, 08:03:30 PM »
Same ones as you have. They work ok for the very occasional time I get caught in the rain with Red. I have them on the Jalopy too, and they leave a lot to be desired in the snow and ice. They are a step up from the vacuum ones that Ted has.
« Last Edit: March 08, 2015, 08:04:24 PM by garage_gnome »
Offline corpsman
Re: '52 M38
« Reply #284 on: March 09, 2015, 12:31:52 AM »
the M38 looks great!
1952 M38
