Author Topic: A 1967 CJ-5 with a 4 diesel  (Read 48830 times)
Re: A 1967 CJ-5 with a 4 diesel
« Reply #30 on: August 12, 2014, 08:52:56 PM »
3A is not worried anymore. This is the RIP picture for the diesel jeep.
Offline johnrb3b
    • Jeeps and stuff
« Reply #31 on: August 14, 2014, 04:32:35 PM »
What do you mean RIP?
Is it dead?
Is it too far gone to restore?
What?
Offline Jeepermc
« Reply #32 on: August 14, 2014, 05:58:41 PM »
He's using the diesel drivetrain for his CJ-6 build. The 5 however doesn't look as bad as it used to. It probably is restorable.
1966 Perkins CJ-6
1952 CJ3A
1951 M38
1957 FC-150 x 2
« Reply #33 on: August 20, 2014, 07:31:19 PM »
I tested the motor yesterday. It starded very easily. I will post vid�o of it. Now i dont know what to do with it anymore, i found a 1"3/4 crack in the block. :-((((
« Last Edit: October 01, 2014, 02:10:24 PM by QuebecJeep »
« Reply #34 on: August 20, 2014, 09:42:29 PM »
Pascal,
I'm sorry to hear about your loss. :-/
« Reply #35 on: August 21, 2014, 05:51:11 AM »
Many cracks can be repaired.
Offline johnrb3b
    • Jeeps and stuff
« Reply #36 on: August 21, 2014, 11:07:12 AM »
JB Weld for non-critical areas.
Stiching for critical cracks.
« Reply #37 on: August 21, 2014, 09:21:15 PM »
Ok I tryed to post vids here but the forum is limited...
So I tryed to start my own channel on youtube here:
https://www.youtube.com/channel/UCggX9WvmZwKkXWzrtVKfafQ/feed
Does it work?
Or I also posted the link to youtube video on my own website here:
http://jeepwillysworld.com/blog/category/my-dj-6-1965-project/
Is it better?
Anyway, what I should do to fix it easily and quickly? I don't have a welder nor a friend with it... :-[
Loctite weld cold stuff, JB weld... other???
« Reply #38 on: August 22, 2014, 07:42:06 PM »
Personally I would not try to weld that block unless it was an expert welder with lots of experience welding engine blocks. To me it is the perfect candidate for stitching. http://www.locknstitch.com/
You could try epoxy but I think it would be a temporary repair. Another thought is modern block sealer that would be added to the coolant. They have come a long way since the good old days.
« Reply #39 on: August 23, 2014, 10:52:32 AM »
Interesting. I sended them an e-mail requesting more information about it. They will be able to see my vids and should reply with a proposition I guess. I'll let you know. Thank Bob.
Modified;
I already got an answer from locknstich.
"It looks like it is into the oil. You need to robe the oil pan and find pit where the crack comes through to the inside. It can be easily stitched but metal shavings cannot be allowed inside the crankcase. It is possible you may find the crack extends into a main bearing saddle or some where that could explain the cause of the crack. "
« Last Edit: August 23, 2014, 12:20:03 PM by QuebecJeep »
Offline Jeepermc
« Reply #40 on: September 30, 2014, 01:50:54 PM »
My block is actually broken and patched. Probably a big chunk missing under the patch. It's the opposite side of the block from the other perkins we've seen with a windowed block from #3. I've seen guys stitch powerstroke blocks, It should work for your perkins also.
1966 Perkins CJ-6
1952 CJ3A
1951 M38
1957 FC-150 x 2
« Reply #41 on: October 01, 2014, 11:25:42 AM »
That's a big patch.
I choose to go with JB Weld for now.
Offline johnrb3b
    • Jeeps and stuff
« Reply #42 on: October 02, 2014, 01:10:58 PM »
Be sure to let us know how the JB Weld worked.
It's always promoted as the miracle cure for all things broken.
I'd like to see it actually do some of the heavy duty repair it claims to do.
Offline Jeepermc
« Reply #43 on: October 02, 2014, 05:18:44 PM »
That's a big patch.
Yes. Very big patch indeed. Not sure who did it but it would not have been my repair method had I had the jeep at the time it went "bang!" If I ever pull the engine for rebuild, I will likely take the block to a professional welder to have it repaired correctly.
1966 Perkins CJ-6
1952 CJ3A
1951 M38
1957 FC-150 x 2
« Reply #44 on: October 09, 2014, 05:58:23 PM »
I have a T98 transmission with a DANA transfert case.
I was expecting a T86 with a spicer transfert case.
Pics will follow later
