Author Topic: A 1967 CJ-5 with a 4 diesel  (Read 48829 times)
Re: A 1967 CJ-5 with a 4 diesel
« Reply #45 on: October 09, 2014, 06:52:09 PM »
T98
Offline Jeepermc
« Reply #46 on: October 10, 2014, 06:44:36 PM »
That's very interesting. Mine has a T-90 as did most of them I believe. I've only seen evidence of one other diesel CJ with a T98.
1966 Perkins CJ-6
1952 CJ3A
1951 M38
1957 FC-150 x 2
« Reply #47 on: November 06, 2014, 08:35:29 PM »
A short update,
The engine is now in the garage. I will dismantle both diff tomorrow and trow away the frame.
« Reply #48 on: November 07, 2014, 08:52:54 AM »
Anyone here are familiar with a T98?
Look like I have extra spacer on the cross member from the tranny and I wonder if they were added because of the T98 or if it is just a Bubba stuff?
« Reply #49 on: November 07, 2014, 03:28:35 PM »
Also, the T98 should be a 4 speed trans, right?
So my shift pattern should look like:
Offline Jeepermc
« Reply #50 on: August 28, 2015, 05:22:45 PM »
that is the shift pattern of the T98 in my Dad's M38. I would make sure reverse is over and up and not over and down. That's the only thing I can't recall clearly 100%.
It looks like bubba work on the crossmember, however my Jeep has/had wood spacers that were between the frame and crossmember that I believe were stock spacers. Your jeep probably had something there also that was replaced by bubba with what's currently there.
« Last Edit: August 28, 2015, 05:23:57 PM by Jeepermc »
1966 Perkins CJ-6
1952 CJ3A
1951 M38
1957 FC-150 x 2
Offline cbauer
  • Lead, Follow or get out of my way
« Reply #51 on: September 02, 2015, 09:16:16 PM »
originaly our 66 cj5 had a wood spacer at the trans crossmember at that very location.
Offline cbauer
« Reply #52 on: September 02, 2015, 09:17:19 PM »
ours is a t98 and d18 transfer 3 speed
