Author Topic: One Owner CJ3A Restoration  (Read 22627 times)
Offline mtnman37879
  • Plays With Jeeps
Re: One Owner CJ3A Restoration
« Reply #15 on: June 23, 2017, 09:58:27 AM »
I haven't posted in a while still recovering from Major Surgery. Here's some pictures, The steering box awaiting a new sector shaft. It should be in the mail today, a Crown part from Quarter Ton And Military.� The shaft had very little wear but it was twisted at the splines. The box is getting a complete rebuild, bearings, seals, horn button and wheel.
« Last Edit: June 23, 2017, 10:01:55 AM by mtnman37879 »
Offline mtnman37879
  • Plays With Jeeps
« Reply #16 on: June 24, 2017, 07:50:40 PM »
Steering box complete! New bearings, bushings, and sector shaft, a complete rebuild. Steers like a new one. The sector shaft wasn't too worn but it had a twist at the splines.
Offline mtnman37879
  • Plays With Jeeps
« Reply #17 on: August 30, 2017, 12:04:06 PM »
Been working on the wheels, I had four and I bought one more for the spare. The spare was dated 1947 but the four that came with the Jeep were all dated 1950, the year of the Jeep, original wheels. In the picture the one on the floor on the left is what the fronts looked like, the middle one is the rear view and the right side one is cleaned and ready for paint. The two red ones are complete. Regal Red is the color that they will be. The Jeeps body will be Black.
« Reply #18 on: August 30, 2017, 01:15:06 PM »
They look great.....after many paint samples I also decided Regal Red looked the best...
I let them bake in the sun after painting....right or wrong they have held up well....
« Last Edit: August 30, 2017, 01:21:10 PM by 1955CJ-5 »
« Reply #19 on: September 06, 2017, 01:17:06 PM »
Nice Job
Offline mtnman37879
  • Plays With Jeeps
« Reply #20 on: September 07, 2017, 04:52:47 PM »
The wheels are done, now to let the paint cure for a couple of weeks then it's off to the tire shop to have the tires mounted! The four wheels that came on the Jeep are dated 1950, original wheels. The fifth I bought for the spare and it's a 1947.
« Last Edit: September 07, 2017, 04:55:41 PM by mtnman37879 »
« Reply #21 on: September 07, 2017, 07:11:04 PM »
Those look great, and should really look good with the black body color..I almost bought Traxions....in fact I ordered Traxions and immediately called back and changed to NDCC's...
Are yours 15" or 16"? Mine are 15's and were most likely original..
Offline mtnman37879
  • Plays With Jeeps
« Reply #22 on: September 08, 2017, 07:23:14 AM »
Mine are 16" and came from the factory with them. Everything about this jeep is still factory original. A rare find.
« Reply #23 on: September 08, 2017, 01:34:00 PM »
Is there anything in the historical documentation that mentions an engine replacement at some point?
Offline mtnman37879
  • Plays With Jeeps
« Reply #24 on: September 08, 2017, 06:48:26 PM »
No, but the engine has been changed. It now has a Kaiser Supersonic engine and It's a Jasper rebuild. The warning tags from Jasper are still on the engine.
Offline mtnman37879
  • Plays With Jeeps
« Reply #25 on: September 13, 2017, 04:21:22 PM »
The rear end is complete and ready for paint. New bearings, seals and hubs. Also added 11" brakes.
Offline mtnman37879
  • Plays With Jeeps
« Reply #26 on: November 10, 2017, 11:42:02 PM »
I've been busy on the 1950 for the last couple of weeks. Getting a lot done. New floors, hat channels, several body panels and some reinforcements. The tub's getting close to primer.
« Last Edit: November 10, 2017, 11:47:21 PM by mtnman37879 »
Offline mtnman37879
  • Plays With Jeeps
« Reply #27 on: March 22, 2018, 05:17:21 PM »
Some assembly required! This is the front axle of my 1950 CJ3A. Every surface has been cleaned and inspected. Every hole has been tapped and every thread has been chased. The balls have been polished and everything that should be painted has been primed. The spindles have been re-bushed and the nuts have been renewed. The axles had oil seal wear grooves, those have been sleeved. The lockouts have been cleaned and the bearings will be replaced. Now for the assembly! Soon she'll be getting a paint job, the final step.
« Last Edit: March 22, 2018, 05:26:06 PM by mtnman37879 »
Offline mtnman37879
  • Plays With Jeeps
« Reply #28 on: April 13, 2018, 09:59:15 PM »
Got a bunch more work done. The axles are ready to install. Every bearing, and every seal have been replaced. All the clearances have been set, both front and rear gear sets are cutting almost perfectly. 11" brake backing plates installed. Painted and ready to hang under the frame.
Offline MGYs
« Reply #29 on: April 14, 2018, 02:16:19 AM »
Thanks for sharing those pictures! You helped me in that I couldn't remember how the rear brake line T-fitting was installed, so I fabricated an L bracket. Then I saw your rear axle pic. Now I know where that piece I was holding in my hand the other day is supposed to go! [smiley=2vrolijk_08.gif]
Please let me return the favor (or possibly cause you grief, for which I apologize in advance). On my front axle, I had the following tags.
