Author Topic: 1952 CJ-3A in Rhode Island  (Read 115585 times)
Re: 1952 CJ-3A in Rhode Island
« Reply #75 on: June 05, 2015, 04:49:02 PM »
That is quite a difference.  My guess is your original may not have been deep enough to do any good.  Here is a decent explanation from the 2A page that helps explain...
http://www.thecj2apage.com/forums/output-shaft-yoke-companion-flange_topic13719.html
« Reply #76 on: June 05, 2015, 08:06:54 PM »
Sweet thanks Tim!
« Reply #77 on: June 15, 2015, 04:00:02 PM »
Today I spent a little while tearing apart my Ross Steering box from my Willys, pretty straight forward. I have not put it together yet because I am looking to get the rebuild kit from Walcks
When I pulled off the steering wheel, which was very difficult, no matter what the You Tube people say, I gaffed up my steering shaft  and needed a replacement. The used one I purchased unfortunately is the wrong length� so the search is on�
Does anyone have an opinion about the length of the steering shaft? Good bad or indifferent?
« Reply #78 on: June 25, 2015, 02:57:55 PM »
I was able to find a worm shaft locally here used for $45 and it is really good shape, came with a steering box and the sector shaft is in good shape as well.
I wonder if anyone has an opinion on coating the worm shaft with something? I should say the section that resides within the steering column. Either paint or grease?
Looks like they don't really have anything on them and I just think that maybe there should be? :-/
« Last Edit: June 27, 2015, 05:45:17 AM by Kirkski »
« Reply #79 on: July 07, 2015, 11:53:10 PM »
I don't think you want paint in there...it will no doubt flake off and just make a mess.
Eventually you will have 140wt gear oil or something similar in the steering box.
I used engine/transmission assembly lube when I put mine together. It just seemed like it needed something....
« Reply #80 on: July 11, 2015, 06:45:58 AM »
Thank you!
« Reply #81 on: July 28, 2015, 12:03:15 PM »
All,
Yesterday I took my oil filter apart and cleaned the inside as well as I could. What I noticed was a lot of sediment on the bottom of the cup. So much so it was very silvery in color and almost rubber like. I just wasn't sure if it was in fact a rubber seal or I really did have all that sediment.
 I hope I got it all out it was a lot.
 Also, I see the C-3 drop in filter on the Walcks website, do any of you know anywhere else to get them?
« Reply #82 on: August 04, 2015, 05:55:57 PM »
Got a call from the machine shop this afternoon!!! Engine is machined and together, they need the bits I have to get it running on the engine stand.
Great news but, my distributor has not come home from Willys Distributor yet� :-[
And looks like I am have a more difficult time finding a shop to rebuild my radiator, do you think a replacement is the way to go?� �:-/
« Last Edit: August 06, 2015, 10:20:03 AM by Kirkski »
Offline LeeC
« Reply #83 on: August 31, 2015, 07:50:42 PM »
Where did you find those tires and if you don't mind how much were they. I'm in Mass. so not far, I need 6 so I hope they weren't too much.
« Reply #84 on: September 01, 2015, 11:01:36 AM »
Hi LeeC, I got them through Summit Racing the were the cheapest I found at the time.
I got the tires, tubes and inner rim bands at the same time and for 5 it was about $1000.
I did return the inner rim bands though I did not have them when I removed the tires and I could not figure out how I could possibly get them in, there was a lot of rubber
Kirk
Offline LeeC
« Reply #85 on: September 01, 2015, 04:03:10 PM »
Thanks for the info,  I found a place in Nebraska for $110.00 each but I don't know about the shipping. It would probably be cheaper at Summit, I've bought lots of stuff from them and like their service. Now that you mention it I need 7.
« Reply #86 on: September 13, 2015, 08:47:32 AM »
Well, got the distributor back from Willys Distributor and brought to the machine shop. They say they will have the engine running next week on the stand, really looking forward to that!
Got the transmission back and installed�
« Reply #87 on: October 06, 2015, 01:53:57 PM »
Getting closer to coming back to life :D
« Reply #88 on: October 07, 2015, 10:16:43 PM »
Wow.  Very nice.
« Reply #89 on: October 08, 2015, 02:59:53 PM »
Thanks Tim, IT'S ALIVE!! First time since 1981 best I know ;D
