Author Topic: 1952 CJ-3A in Rhode Island  (Read 115581 times)
Re: 1952 CJ-3A in Rhode Island
« Reply #105 on: November 09, 2015, 10:03:21 PM »
It's about all that consumes my thoughts
Boy can I relate to this!  A word of caution...it won't go away.  In fact, once the tub is on, it gets even worse. :o
You'll stand out in the garage for hours just staring at it.
« Reply #106 on: November 09, 2015, 10:47:10 PM »
I have a storage unit where the two jeeps are now kept...but when I first moved the 3a over there I had terrible separation anxiety....
But when it's occasionally back in the garage I often just go out and look at it... :)
« Reply #107 on: November 10, 2015, 07:09:45 AM »
I'm so glad I don't have to fight this disease alone and we have this support group :D
« Last Edit: November 10, 2015, 07:10:09 AM by Kirkski »
« Reply #108 on: November 13, 2015, 04:01:38 PM »
Prepping the grill for paint
« Reply #109 on: November 21, 2015, 10:54:49 AM »
Grill is painted and installed, I am really happy with my color choice, after months of agonizing... :-/
In different lighting the effects are really neat, you can see blue or green. I was thrilled that my body work came out well, its been 34 years since I have done any of that, don't have the hands I should but I can't see any issues.
Bolted on the radiator an shroud, installed new welting. Getting close... :D
« Reply #110 on: November 21, 2015, 11:36:29 AM »
Looks great! Are you going to bolt an oddball seat on the frame and go for the obligatory Rolling Chassis Test Drive?
« Reply #111 on: November 21, 2015, 08:42:57 PM »
Oh yes you must drive the bare chassis around....lots of fun...you will wonder why you need a tub!
Faux wicker for a seat is perfect! I used a patio chair and removed the legs...
I really like the color...
« Last Edit: November 21, 2015, 08:44:10 PM by 1955CJ-5 »
« Reply #112 on: November 21, 2015, 09:36:07 PM »
Ryan and Randy you bet I am going to be riding this chassis around, I go to bed every night thinking about it and dwelling on it everyday.
My wife says I'm obsessed� I tend to agree :o
« Reply #113 on: November 21, 2015, 11:26:07 PM »
Very cool color!
« Reply #114 on: November 22, 2015, 06:32:18 AM »
Very very nice.  That wheel against that gray is a very bold contrast.  I really like it.
Be sure to check out Tim's (athawk11�s) chassis test drive set up.  Almost more comfortable than the stock set up.
« Reply #115 on: November 22, 2015, 09:05:28 AM »
Looking good! Love the Grey against the wheels. Make sure the steering wheel nut is on. Hawky forgot his and drove like a race driver. I'll never forget it. John
« Reply #116 on: December 02, 2015, 03:44:11 PM »
Ok, I am now in need of help with creating a make shift electrical circuit to start my Jeep and test drive it.
 I have a key start that has 4 posts on it
 ACC, ST, IC, AM
 I have a solenoid on the starter and it is 6 Volt
 I assume that IC would be to the Ignition Coil, since I am not connecting the Ammeter I'm not sure what to do with the lug off of the solenoid, does that go to the ST or AM?
 All of the drawings that I have looked at don't seem to be very helpful.
Thanks
 Kirk
« Reply #117 on: December 02, 2015, 04:52:59 PM »
Kirk,
I agree with your guess on the IC being ignition coil.  You would just wire directly from the IC post to the + side of your coil.
-ACC is probably accessories.
-ST is "start" which will go to the small post on the solenoid.
-AM...hmmm...not sure.  But You will need a connection to the Battery. You can see this attaches to the solenoid in my drawing.  (same large post that the + side of the battery attaches to.)
Here is a basic drawing I put together for another Willys guy that was setting up to do a chassis run.  He had a basic push start button in the equation (which you won't need)...and a universal key switch which was a bit odd.  Label wise, he couldn't really tell me what he was seeing on it.
Hopefully this will help you a little.  This is really all you need to start and run around a bit.
« Reply #118 on: December 02, 2015, 06:27:56 PM »
Tim, i'm saving all of your hand drawing. It's amazing how much it look easy. We (forum members) are lucky to have you sharing your knowledge. Thank.
« Reply #119 on: December 03, 2015, 07:28:03 AM »
Tim, Ever thought about moving to Rhode Island? Could really appreciate having you as a neighbor..
Thank you again for your timely response..
Giving it a whirl today I hope� fingers crossed I'll have an update later today...
