Author Topic: Hawk's CJ3A 13655  (Read 225744 times)
Re: Hawk's 1949 CJ3A
« Reply #210 on: July 22, 2014, 07:36:21 AM »
While I groaned reading this I would have groaned louder if you already has the tub back on before you discovered these problems. There's a reason you've been driving around the neighborhood like a wild-man in your open wheeled contraption. You wanted to shake out any issues and you did. I'll be waiting patiently for the update on the resolution.
Check your PM's btw. You have a dusty one sitting there.
Ryan
« Last Edit: July 22, 2014, 07:36:52 AM by Ryan_M »
Offline macrisel
« Reply #211 on: July 22, 2014, 11:09:40 AM »
I have to agree with Ryan.  It stinks that you have to rebuild the tranny, but better now with the body off than later (like I did).  Having pulled my transmission/transfer both with the body off and with it on, I can tell I thought very seriously about pulling the tub off this time to rebuild the transmission!
I think you are doing the right thing with a new clutch, pressure plate and bushing.  On something that is that difficult to get to, I would error on the side of caution and replace things also.  My shop time is getting more and more limited so it's easier for me to justify the $160 now for a kit than try to carve out another week later to replace it.
I wish I would have spent more time driving my chassis around to troubleshoot problems!
« Reply #212 on: July 22, 2014, 07:01:20 PM »
Mark, Ryan,
Knowing that you are the two fellas that have the most recent  experience with transmission rebuilds, I was hoping to hear from you on this.  I may be leaning on you both once the parts arrive.  Hopefully that's okay. :-/
Offline macrisel
« Reply #213 on: July 23, 2014, 05:56:41 PM »
Absolutely! [smiley=thumbsup.gif]
(Although Ryan has twice the expericence as I do. ;))
Offline zooke581
« Reply #214 on: July 24, 2014, 08:33:27 AM »
My transmission is leaking on all the gaskets and seals I thought didn't need replaced.  It is doing the same as yours while shifting.  I am rebuilding another to put in.
It will be interesting to see if we have the same things to correct.
« Reply #215 on: July 28, 2014, 09:48:00 PM »
Well, here they are.� NOS synchro rings...Made In The USA.�
Ironically, they came all the way from Athens, Greece.� Go figure....
I'm almost ready to rebuild the transmission and clutch system.� My clutch kit has arrived, but the pilot bushing is missing from the box.� I'm hoping to get this issue resolved soon.
I put some effort into finishing up the grille.� A small amount of filler along with a half dozen coats of filler primer with sanding in between.� Smooth as a babies bottom...
Next installment,� �T-90 Transmission.
« Last Edit: November 05, 2017, 04:03:07 PM by athawk11 »
Offline zooke581
« Reply #216 on: July 28, 2014, 10:13:08 PM »
Yep as my Mom would say (she is Dutch)  Smooth as a Kinder's Popo.  ::) ;)
« Reply #217 on: July 28, 2014, 10:21:54 PM »
The syncro rings look good...did you get them on ebay?  There are a couple of overseas sellers that have interesting stuff..I got a temp gauge from the fellow in the Netherlands...didn't use it, but I got it!
« Reply #218 on: July 28, 2014, 11:06:53 PM »
Randy,
Yes...eBay...a nice fellow from Greece.� He had listed NOS� rings, but didn't mention the country of origin.� I wanted two sets if they were USA parts.
I contacted him to ask.� I mentioned my concerns about offshore parts.� He said the set for sale was made in India, and these rings have been well tested in the Mahindra Jeeps.� He felt they were every bit as good as the US made rings.� Turns out, he had USA stuff too.� We negotiated... We agreed that he would send me a set of each.� I also have a set coming from the offshore supplier.� Omix?� Crown?� Who knows.� I intend on comparing them all...side by side. I'm no metalurgist, but I will inspect and measure them.� Should be interesting.
Tim�
« Reply #219 on: July 28, 2014, 11:25:00 PM »
Great idea, Tim...comparing the parts side by side.  should be interesting.  Do we need a new area for this kind of info?
Did the wife pick out a color yet for her new ride?
« Reply #220 on: July 28, 2014, 11:50:11 PM »
Hi Tom,
She wants a pale yellow.� She picked a color.� I sprayed an old hood.� She thought it was too pale...almost cream.� I liked it.� She didn't.� We're close, but the search continues.
Thanks for looking in!
PS: Good idea on posting to specific section.� If it ends up being kind of interesting, I'll post the info in the new "Gear Boxes" section.
« Last Edit: July 28, 2014, 11:54:41 PM by athawk11 »
« Reply #221 on: July 29, 2014, 12:31:53 PM »
Thanks Tim,
I'll sure be watching your rebuild.....the "whine" in my transmission is getting annoying...it's not any worse than it was, and maybe a bit quieter, but it's taking the fun out of driving.....so another more careful rebuild may be in my future...
I'm going to remove the OD and reinstall the old output gear and see if that changes anything...
We eagerly anticipate pictures etc...and no "whining!"
« Reply #222 on: August 17, 2014, 08:52:22 PM »
A short, but painful update.� Well, not too painful.� The transmission rebuild went well.� The new pressure plate, clutch, and bushing were installed also.� I re-installed the drivetrain and my temporary seating.� Time for a test drive.
The engine fired right up.� I attempted to slide her into 1st gear...and...grrrr grr gr....gear grind.� The clutch would not disengage.� I diddled around with the clutch cable for half a day.� Nothing I did helped.
I finally realized that the drivetrain needed to be pulled again.� Anyone else notice how good you get at stuff like this when you have to do it two or three times in a row?
Anyway, after reading a bunch of threads, I found that any of a number of things can cause this.� Not wanting to have to pull the drivetrain again, (3 times was enough) I decided to address every possible issue. The result of this choice is that I have no idea what my original problem was.
 I installed a new pivot fulcrum and clutch fork.� The new clutch disc had a very slight warp. The old disc was, well, pretty new, so I put it back in.� The bushing was pulled, then slid onto the input shaft.� It seemed a little tight, so I reamed it out a bit.�
I re-installed the drive train and my temp seating. I fired up the engine, then pushed in the clutch. I let out a sigh of relief, then took the chassis for a spin.�
Everything went fairly well except shifting into 2nd gear.� Synchros work great, but the shifter just won't throw the gear far enough to keep it engaged.� It just barely catches, but occasionally slips out.�
I inspected the shift fork and found some decent wear groves on both sides of the fork.� The wear is even, but I am missing 3/64" of material.� I don't know if this is enough to cause my problem, but I decided to get a new fork anyway.� I will also trim some material from the poppet groove, as described in the Willys memo we have all seen recently.
This will probably be the last project I do on Whitey for a while.� In preparation for the Fall Colors Tour, I have a number of small projects planned for the OD Willys.� New brake shoes, valve adjustment, new fuel pump, oil change, etc...
« Reply #223 on: August 18, 2014, 07:50:17 PM »
Walcks supplies the rivets, but I don�t have a tool to use them as rivets.� I threaded them, and then bolted them on.�
 Tim,
   I am curious what die did you use to thread these rivets? I'd like to do the same.
  Thanks in advance
   Kirk
« Reply #224 on: August 18, 2014, 08:26:24 PM »
Hi Kirk,
I brought a photo forward so folks would know what we're talking about...
I used a 3/8" corse thread die to cut the threads.� It was a little tricky.� I grabbed onto the head with a vise grip, then used the die to cut the thread.� The metal is fairly soft, so cutting threads works pretty well, but it was pretty easy to dig into the head with the vise grip.� I tried to only grab the head hard enough to hold the rivets from spinning but still cut the threads with the die.� If you look closely at the photo, you can see some notches left by the vise grip.� When I did dig into the edges a little too much, I cleaned the head up with a file.
Hope this helps.
« Last Edit: October 16, 2017, 04:31:19 PM by athawk11 »
