Author Topic: Too rusty to save?  (Read 213739 times)
0 Members and 10 Guests are viewing this topic.
Re: Too rusty to save?
« Reply #270 on: July 04, 2013, 08:51:39 AM »
Very cool pump. 8-) Love the glass tops.
« Reply #271 on: July 04, 2013, 10:48:55 AM »
Thanks Tim,
The rebuild wasn't that bad, there was a lot of head scratching trying to figure out how to get the machine pressed parts separated without ruining them.
I'd do another...
This was on a jeep that was for sale....It kinda proves that a jeep will run on almost anything...
Click on it..it's a short video.....
« Last Edit: July 04, 2013, 10:55:02 AM by 1955CJ-5 »
« Reply #272 on: July 05, 2013, 08:59:08 PM »
I installed the heat riser into the new/old manifold today..
I had to weld the flapper to the shaft..
« Reply #273 on: July 05, 2013, 09:01:08 PM »
It works!
Cold..
After warming with a heat gun..
« Reply #274 on: July 05, 2013, 09:04:19 PM »
I'm putting the various components back on the engine....
And I set the timing when installing the distributor...
Offline NoCoWillys
« Reply #275 on: July 06, 2013, 01:57:05 PM »
That motor almost looks too clean!
'53 CJ3a
« Reply #276 on: July 06, 2013, 06:49:55 PM »
Give me a chance to spill something on it!! :D
Here is a "before" picture...
« Last Edit: July 06, 2013, 06:53:49 PM by 1955CJ-5 »
« Reply #277 on: July 07, 2013, 09:51:23 PM »
I did not have the anchor for the throttle return spring, but I had the one for the emergency brake....so I copied it...i think it'll work fine...
And I straightened and welded the old spare tire carrier..
It's nearly time to put the manifolds on...hoses are in, I'll add the fuel pump next..
« Reply #278 on: July 07, 2013, 09:55:14 PM »
I searched for a color match for the oil filter housing..
somewhere i read about a Duplicolor Chrysler engine paint..
The right half is painted with the duplicolor, the left is still the original paint...pretty darn close
now that adds a little color!
The paint is Duplicolor Chrysler Hemi Orange engine paint..DE1652
« Reply #279 on: July 07, 2013, 10:14:28 PM »
The jeep came with this governor mounting bracket...I'll re-install it, just in case I find a governor one of these days...
It reads:  "Warning  Do Not engage or Disengage Governor While engine Is Running"
I've read that this refers to a Monarch governor..but a Novi would do...
« Reply #280 on: July 09, 2013, 12:52:55 AM »
Fuel pump, manifolds, carb, water pump etc..busy day!
« Reply #281 on: July 12, 2013, 04:27:09 PM »
I've been doing some body work in the mornings when it's still cool enough..the metal storage unit is like an oven in the afternoon...
But mostly I've been cleaning the old parts and brackets etc.
Can you see the connection for the heater hose on the water pump in the second picture? At that angle it won't work as the hose hits the oil filter bracket...the heater connection on the old pump was on the other side  near the output...
any suggestions?
My CJ-5 has a curved hose connection there and that works fine...
« Last Edit: July 12, 2013, 04:30:01 PM by 1955CJ-5 »
« Reply #282 on: July 12, 2013, 04:38:09 PM »
This was my approach to the same issue...
I think I picked it up at Lowes or Home Depot.
« Reply #283 on: July 12, 2013, 04:50:36 PM »
Thanks Tim, that looks perfect...I figured there must be something out there that would work, I have not seen another curved one as on the CJ-5...
You might be able to see it here...
« Last Edit: July 12, 2013, 05:09:00 PM by 1955CJ-5 »
« Reply #284 on: July 15, 2013, 10:33:14 PM »
Picked up the wheels, grill and tailgate from the sandblaster today...I'll try and get them primed tomorrow if it's not too hot...
Four of the wheels are riveted K-H 15 x 4.5, and the fifth is the same size and profile, though it's not marked K-H and it's not riveted...
