Author Topic: Too rusty to save?  (Read 212446 times)
Re: Too rusty to save?
« Reply #285 on: July 18, 2013, 11:20:52 PM »
This body work turns out to be quite a long process.....fill a little, sand a lot, fill some more, sand some more, maybe a little primer, then a little glaze, sand and fill sand and fill.
But I'm getting there...
Not so long ago..
Today
« Reply #286 on: July 22, 2013, 12:25:05 AM »
After the encouragement from another thread, I tackled the left front fender...
Looks OK..
I'm not sure what to do here....
« Reply #287 on: July 22, 2013, 10:37:26 PM »
Today I cut out the rust where the fender bolts to the tub..
One patch made...
« Reply #288 on: July 23, 2013, 10:57:09 AM »
Very nice.  I have a sneaking suspicion that you are enjoying this process too much.  Will there be another?
I know you've probably mentioned it in your thread somewhere...
What type of rust preventative primer are you using?
« Reply #289 on: July 23, 2013, 04:41:54 PM »
Hi Tim,
Somewhere early on it was mentioned that I take it one little piece at a time, and don't stand too far back and look at the whole project as it's easy to be overwhelmed...
When I remember to do that it is lots of fun....
There is a fairly complete M-38 around here, if he hasn't sold it.....but my jeep fund dried up about a month (or was that two months?) ago.....but, still.... ;)
I used SEM 39304 rust converter. It is classified as a primer, according to the bottle...but I put Eastwood 2k epoxy primer over that.
If I were to do it again I'd really have to consider having it sand blasted and then shooting 2K primer with a proper spray gun..I spent too many $$$ on spray cans ....
« Last Edit: July 23, 2013, 04:44:37 PM by 1955CJ-5 »
Offline gmcjr
« Reply #290 on: July 23, 2013, 08:48:04 PM »
WOW! Between and Tim, I get exhausted just looking at what y'all two get accomplished! Your going to have a real good looking jeep.
Gary in N. Texas
51 CJ-3A (old Trusty)
52 Ford 8n (ugly duckling)
46Farmall B (old Rusty)
18 Wrangler Jk
« Reply #291 on: July 24, 2013, 02:33:21 PM »
Exhausted?  Yes...I know the feeling!
« Reply #292 on: July 25, 2013, 09:12:32 PM »
I think the fender turned out pretty good.....probably my best patch so far and you won't even be able to find it once it's on the jeep...
« Reply #293 on: July 25, 2013, 09:13:48 PM »
More...
And that other big part looks OK too...
« Reply #294 on: July 27, 2013, 10:53:49 PM »
And yet one more little patch....i could have just used a large washer over this hole, but...
And there was this starter solenoid bolted to the inner skirt of the passenger fender...wasn't hooked to anything. Jeep has a kick-start starter and one position ignition switch...so what this was for is anyone's guess...
« Last Edit: July 27, 2013, 10:54:59 PM by 1955CJ-5 »
« Reply #295 on: July 30, 2013, 08:05:34 PM »
Passenger fender repairs.....seems like all you need to do is tell yourself that this one is going to be easy....that automatically makes it twice as difficult..!
« Reply #296 on: July 30, 2013, 09:18:36 PM »
I decided I'm going to send my '49 to you to fix the tub. You do good work!
« Reply #297 on: July 30, 2013, 10:21:16 PM »
I appreciate that... :)
But you better hurry, the more I learn, the more I charge!
« Reply #298 on: July 30, 2013, 10:26:22 PM »
Needing a little encouragement-the 3A has not really looked like a jeep for a while-and having to fit the brace on the driver's fender before welding it in place, I hung the front end loosely together..
Hey, there's a jeep in my garage!
« Reply #299 on: July 31, 2013, 10:57:16 AM »
I've said it before, I'll say it again...very nice work.  I always enjoy mock up days.
Is the grille painted in the final color...White?  Or is that primer?
That solenoid could have been a remnant from days gone by.  Over 60+ years, a different starter may have once been present.
